Mitering butcher block
Justin Szeliga
>I've got a friend who wants to put in a butcher block counter top on a set of cabinets on adjoining walls. She wants a miter joint in the corner for looks. Anyone ever do one like this? I was thinking of using biscuits toward the top of the slab & a couple of countertop joining bolts in the bottom.
Peace
Justin
Re: Mitering butcher block
Re: Mitering butcher block *LINK*
Fred Davis
>Like this?
I didn't use any fastners except screws underneath in slots though the cabinet bracing into the countertop.
I would not try biscuits , since the you need to aligh the top edges perfectly, bolts are good, but not necessary, good help is though.
FredD
http://picasaweb.google.com/FredD17209/CountertopMitre?authkey=iagHreDmcEA&feat=directlink
Ellis Walentine, Host
>I'm in the process of doing this very thing right now, Justin. I routed mating grooves in the two pieces and made a very hard maple spline that fits in the grooves. This keeps the surfaces perfectly aligned. Underneath, I'm using three countertop joining connectors to pull the whole thing together.
Normally, you would glue this joint together so it will remain watertight, but I can't do that because both sections are captive between end walls, so I'd never get it out. So, I've sealed all the parts with thinned polyurethane and I will use a bead of silicone when I yank them together.
The other thing you have to allow for in this type of construction is wood movement. A two-foot-wide butcher block is bound to change dimension over time, so you have to allow the joined-up top to float a bit as the miter angle changes. It shouldn't be much movement, but you still have to allow for it.
Justin Szeliga
>I'm guessing that leaving a bit of a gap, 1/8" heavy at the wall, is what you mean by allowing for expansion? If so, the wall is being tiled so that will cover any gap.
Peace
Justin
Fred Davis
>It's not necessary or even desirable to leave a gap between the countertop and the wall , the opposite , a snug fit is better.
If the Maple butcher block moves at all and that is a very small movement because of the many narrow strips instead of a plank effect , the movement will be toward the front of the cabinet and no one would ever notice .
The tight fit at the joint is what to aim for.
Gluing endgrain of something this massive is kind of useless, if it moves glue wouldn't stop it.
One other note from the leading manufactuer of Butcher blcok in this country , John Boos of Effinghan Ill. is to fasten the top to the cabinet at the back edge of the top and let the weight of the top hold it'self down to the rest of the cabinet, insuring any lateral movement is to the front of the cabinet.
Works for me .
FredD
FredD
Make sure they understand that it will move *LINK*
Grant in Iowa
>If the customer wants it that way, that is fine, but I wouldn't recommend it. Here's why:
Assume you use hard maple(and white oak would be similar), and the countertop is 23" wide. With the moisture content only changing 3%, you'll get a change of 3/16" in width. 7% (very possible) swing will get you a change of 1/2". That change in width will cause a gap in the miter that will be very noticeable. As the counter swells, the miter will open at the rear, and as it shrinks, it will open at the front. I think any attempt at forcing the miter tight by using countertop bolts will cause either splitting or warping or movement along a wall seam or ??? Expanding wood can split stone, so it should be thought of as an irresistable force.
Installing bolts will at best force the overall angle (90 degrees) to change about 2-3 degrees, which will cause issues at the opposite ends of the top, tearing it away from the wall or whatever.
I'd try to explain that to the customer and suggest a butted joint, which can be bolted together as you suggest, allowing for lateral movement by bedding the tops in silicone (nice and thick beads, supported by shims while the silicone hardens). Such an arrangement should yield a tight joint that will stay more or less tight.
I'm sure someone else here will chime in and share an experience with this type of joint on a wide board.
FWIW,
Grant in Iowa
Shrinkage calculator at Woodweb
Re: Make sure they understand that it will move
Dick Coers
>Isn't the majority of the expansion change vertically? I thought they orient the growth rings so the top won't expand so much from front to back.
Fred Davis
>Justin,
contrary to what you may hear , there is no problem with expansion and contraction with a Hard Maple top cut on a mitre, if the fastening goes along with established procedure , fastening at the back and using slotted screws along the mitre to hold the edges down and leaving the rest of the front edge float free of fasteners.
Countertop bolts are typically used for less massive counters like Formica over particle board, but they do hold well.
What I think you may have a problem with ,unless you have done this before is getting a acceptably tight joint , that is eye pleasing.
The counter in our kitchen which has a 22 1/2 degree bend in the wall was a natural for the mitre, however , along the other side of the range for strength consideration I used a butt joint on the 90 degree corner and farther down at the fridge where the counter returned only 12 inches , I butted that also.
Be sure to seal all cuts you make, I use Howards Feed and Wax , which is a Beeswax and Orange oil concoction which we also use on the countertop .
John Boos makes a similar product they call "Magic Oil" but Howards is generally available locally and just as good.
Hope this is clear enough to help you decide which way to jump. ;-))
FredD
Countertop connectors
>Hi Fred,
I've used countertop connectors for all different thicknesses of wood, including leg-to-rail bedpost joints. They're thin enough to use on 3/4" plywood tops, but there's no reason you can't set them at whatever depth to keep the pressure centered on the edge. They result in a very tight, clean-looking fit, whether or not you use glue, which I admit has little strength on 45� endgrain. I use glue to seal the crack.
And regarding your recommended installation method, I note that you are also recommending letting the tops float. That was my point. You cannot affix both tops tightly to the counters and expect the miter to stay closed during heating season. Whether you join the tops to each other or screw them down along the miter, you're essentially fixing the miters relative to each other and letting the rest of the top float. I prefer connectors because they actually clamp the two tops together.
Re: Countertop connectors
Fred Davis
>Hi back at ya Ellis,
If you reread my post , I said " bolts were good " , though I did not use them for mitre connection with wood countertops.
The installation method I wrote about was from John Boos and company, a leading manufacturer of Maple tops recommendation which I use and have found to be right on.
Lastly the photos I posted are living proof that way works.
Which of course does not preclude other ways to skin the cat.
But , like I said to Justin who asked because he did not know, I still think in his instance the fit and finish are going to be his biggest problem, but I could be wrong ;-))
FredD
