Wolverine Grinding & Honing Jig
Nathan
>Does anyone here use the Wolverine Grinding & Honing Jig from Oneway Manufacturing? Can you recommend it?
I'm considering getting it, along with the grinding wheel dressing jig and the Multi-Gauge, but since these products are rather expensive I thought I'd ask here first.
Thanks in advance,
Nathan
Re: Wolverine Grinding & Honing Jig
paul waddle
>The answer is a resounding YES. Go to the turning forum and post this question. I believe you will get several responses. bcause of their expense,I'm looking for a used one-but haven't had any luck. This Sat only,Wood Crafters will have a 10% off-might help,guess I'll buy one then. You will REALLY need the varigrind(fingernail) attachment to do your bowl gouges. I personnaly want to flat grind my skew,but thats just me. pw
Howard Norman
>Yes, I have the Wolverine Grinding & Honing Jig that you asked about. I am not a big turner but I use it when I am turning. It wasn't cheap but that is the past and I don't think of the cost when I use it now. Go to the turning forum and ask your question and you will get a larger response I am sure.
Pete in Holland, MI
>Very much worth it. In turning, tools need to be sharpened frequently. Fingernail grinds for bowl gouges can be touched up with a .001-.002" taken off per grind, with a perfect edge, in less than 30 seconds away from the lathe. Careful grinding with this jig also results in a longer lasting tool (each sharpening takes away material. Hand sharpening most likely will result in more per grind).
Ed Mulligan, Cape Cod
>It's excellent. I don't do much turning so I never developed the knack for grinding my lathe chisels. The Wolverine allows me to get repeatable results quickly and easily. The how-to videos on their website are very helpful for learning how to use the jigs.
Clarification: I meant the flat tool jig. *LINK*
Nathan
>I see the Wolverine system is popular with turners. That's a good sign.
Actually, though, the jig I'm considering is the "Flat Tool Grinding & Honing Jig". It works with the same base as the turning tool grinding jig.
Looks like it will be good to have. What I really like about it is that it doubles as a honing guide. You clamp the chisel or plane knife in the jig, do the hollow grind, and then go right to the stone. Follow the link for a picture and description. (Obviously, I have no affiliation - I'm still wondering if it's really worth the price.)
Flat Tool Grinding and Honing Jig
Re: Clarification: I meant the flat tool jig.
Ken Garlock, Collin County Texas
>Hi Nathan.
After looking at the OneWay jig, I am inclined to stay with the Veritas MK-II sharpening guide. I don't remember the last time I used a grinder to sharpen a plane blade or a chisel, so that feature doesn't interest me. However, I do use the Wolverine sharpening jig for sharpening my turning tools. It does a good job.
I use the MK-II system to sharpen my "flat" tools on 3 Shapton ceramic stones. It does an excellent job. It has been my limited experience that most "flat" tools come with a sufficiently sharp edge that a good water stone is the order of the day.
Happy Sawdust,
Ken
Re: Clarification
>I, like Ken, use the Wolverine for turning tools. I would not use it on a plane iron because the hollow grind from a 6" or 8" wheel would take too long to remove, plus an 80 grit wheel is much too course for that kind of sharpening, requiring even more time and elbow grease to refine.
JMO-YMMV
my experience
Bill Tindall, E.TN
>I consider the tool rests the best commercially available. They are big(very important) and tools slide on them easily. And the are not wobbly like the LV rest.
I find the wheel dresser useful for truing the roundness of wheels. Hand held dressers can fail to make an out-of-round wheel round. Out of round wheels vibrate the grinder in an annoying way.
The attachment for doing spindle gouges and the one for roughing gouges I find very helpful, in fact essential, for my lack of gouge grinding skills. They work reliably.
The attachment for chisels and plane irons in not necessary. If that is what you are talking about don't buy it as you will in short time not use it. To grind these tools you need to crown the wheel, and using the wonderful large tool rest, free hand grind these edges. Now, you don't do this by plunging the tool straight into the wheel. Rather, you sweep the tool across the crowned wheel left to right and right to left. The crown enables the center of the edge to be ground while not rounding over the corners. Using this very light "touch and go" back and forth motion you slowly grind the edge, checking with a square to see that you are keeping it straight. A few free hand strokes on a flat stone (I use diamond) will reveal if the edge is straight. If not, the crowned wheel will enable the high spots to be preferentially removed. Sounds difficult, but a bit of practice on a junk plane iron will teach you the technique.
Re: Wolverine Grinding & Honing Jig *LINK*
Dick Coers
>For my bench chisels, I use the v holder. Set the handle in the v, and slide the chisel back and forth over the stone. Watch that you don't crown the chisel. For plane blades, I use the Veritas grinding fixture. I hook the bottom slide on top of the Oneway platform and slide it back and forth. Lots cheaper than the Oneway flat jig.
Veritas fixture
John McGaw
>Yes, I've had one since they were first introduced. An excellent addition to the grinder although setting it up and using it properly takes some messing about. This is especially true with the fingernail gouge grinding accessory (they call it the Vari-Grind). This thing can do wonders but getting it adjusted accurately every time can be a nightmare and consistency is important in this type of sharpening if one is to avoid grinding every gouge down to a stump.
paul waddle
>I'm using my makita sharpener for chisels and flat blades. I will NEVER again use the side of the grinder wheel.(he he he). It probably doesn't matter to an expert turner,but I like the skew as flat as possible. I would explore other methods than the Oneway for flat blades,skews etc...JMHO. With gouges,the Oneway is fine as are similar type sharpeners. They allow you to do the compound angle turning the same way each time. I've been trying to buy a used Oneway,guess Marvin will sell me a new one Sat.. pw.
Thanks to all
Nathan
>I ordered the regular jig with the Vee Arm and the big tilting table.
Nathan
