Jointing plywood?
Jointing plywood?
Jointing plywood?
Terry Alexander
>Sometimes a dado for a plywood is just too much of a hassle and not really necessary. However, I would like a clean, 90 Degree, straight edge on my 3/4" plywood.
Are there any "rules" for jointing plywood?
Will it harm my jointer?
Reason I ask is that I don't believe I have ever seen Norm joint plywood and I have seen (I think) all of his programs.
As always...TIA
Terry Alexander in West Texas
Re: Jointing plywood?
Not A Great Idea
>2 reasons.
a. Your edge is usually 50% end grain which will tear out badly.
b. The laminating glue is abrasive and will dull HS steel knives rather quickly.
If I had a carbide Shellix head, I "might" try it. Otherwise, put a bit of time into tuning your table saw to a dead nuts 90� cut and go for it.
Alternative
>You can also set up a router and a guide fence and get a good cut with a good sharp 1/2" or bigger carbide bit. Just take smaller bites, like 3/16" max, at a pass.
HTH
m
edge band?
paul in AZ
>with either the iron-on tape or my preferred route of a 1/4 inch or less strip of wood matching the face wood.
I do it
>I do it, especially when working with Baltic birch, with no apparently worse wear on the jointer than yellow pine. Best way to get a clean, smooth, square edge. No tearout, either.
Clint
mamc
>I've done it as needed. Taken small amounts just to clean up and edge or dial into a certain width. No problems or tearout.
Got a kick out of your Norm comment.
Thankfully I've never seen Norm shower either, but I bet he does it!
Try it I doubt you'll damage anything.
Good luck
Re: I do it
Fred Davis
>I agree with
Clint jointing plycore IF it is all wood and not a sandwich of Particle board or masonite which will dull you jointer knives quickly.
FredD
