THE WOODRAT IS BACK!
Slab Sources???
Slab Sources???
Slab Sources???
>Have been asked to do a live-edge slab dining table. I'm therefore looking for a source of slab stock within a 50mi radius of Trenton, NJ, preferably with a variety of species, where I can take the client and have them pick out the piece they want. They have expressed a preference for a single piece, but will also consider a bookmatch situation. They're looking for at least 39" width and 8/4.
Tried Woodfinder, but the engine is really set up for species-specific searches that aren't helpful in this situation.
TIA
Re: Slab Sources???
Re: Slab Sources???
Joshua A Clark
>This might be a little farther than 50 miles, but I would recommend Berkshire Products in Sheffield, MA. He's got an amazing selection of slabs. Some of his stock is online here: http://www.berkshireproducts.com/prodib1.htm
Hope this helps.
Josh
Re: Slab Sources???
Thanks
>Joshua,
That's too far a hike, and this has to be an in-person choice.
BTW, tried their website and it appears down at this point. I try again later.
Thanks again
mm
Re: Slab Sources???
Thought of another
Joshua A Clark
>You might want to try ML Condon in White Plains. Their lumber selection is fantastic. They don't normally carry a lot of slab wood, but they do have some interesting stuff. Last time I was there they had some cherry burl slabs.
Good luck!
Josh
Re: Slab Sources???
Re: Slab Sources???
Scott in Douglassville, PA
>Mark, you might want to try Hearne's or Talarico's. Both should be within driving distance for you. There are some others nearby, too, but they tend to be smaller; Hearne's and Talarico's generally have a ton of really special stuff.
Good luck.
Re: Slab Sources???
Thanks
>Know Hearn's, but have bookmarked the other.
Re: Slab Sources???
Re: Thought of another
Barry Mabery
>I stopped in M.L. Condon earlier this week and they have expanded their slab selection. They probably had 20 or so slabs - domestic and exotic - in lengths up to 8 ft and varying thicknesses. Pricey, but I saw a very nice cherry and a beautiful walnut slab that I couldn't tear myself away from (but didn't buy).
Re: Slab Sources???
Re: Slab Sources???
Thomas S Stockton
>I used slabs in the search line and a few came up for NJ and PA
Tom
Re: Slab Sources???
He's in Woodfinder, too *LINK*
Ellis Walentine, Host
>Mark, I did a search for "slab" in Woodfinder and found several in NJ and PA. Berkshire Products also shows up there.
Berkshire Products in Woodfinder
Re: Slab Sources???
willardfinefurniture.com
Re: Slab Sources???
Re: Thanks
peter kolb
>I have not been there in a while but Wilard Bros. in Trenton had walnut slabs. Peter in south central NJ
Re: Slab Sources???
Re: Slab Sources???
Joanne in Pt. Pleasant, PA
>You might try John Kirlew at Bucks County Hardwoods. His small mill is in Doylestown (outside of town), down the road from me. He usually has big slabs of walnut and cherry (not sure what else). Email me if you want to try him and I'll send you his cell number.
Re: Slab Sources???
Re: Slab Sources???
Ken Platt (granby, CT)
>As Clint posted, Willard Brothers. They used to have a pretty good selection of slabs. I found their web site at http://www.willardbrothers.net/. I haven't been there in many years, might have changed.
Ken
