What to use for a cross end?
>I want to make some wooden crosses. Sort of like for a large rosary or similar. What to use for an end to suspend the cross though?
A zinc plated "eye" would look sort of tacky. Brass would be better, but I don't know. Antique brass would probably be better than bright brass. I don't know if a hole bored through would work - though it would be the easiest.
Any thoughts? TIA.
Re: What to use for a cross end?
Key Hole
Dustmaker Mike
>I think I would use a keyhole in the back to hang the cross. If you hang it off a chain than this idea would not work, but there are loops that can be hidden on the back of the upright piece.
How large?
Ellis Walentine, Host
Re: How large?
>I was going to make the thickness about 1/2". I was thinking about maybe 2-3" high.
>You could use a router bit that makes a keyhole slot. the bit is basically a tiny wing cutter. You plunge in (or drill a hole) and route up toward the top. The slot is flared open on the inside so that the Cross could be hung form a screw or nail head.
But, why don't you just drill a hole at an angle so that you could just drive a nail in the wall and the hole would match the angle of the nail. Sort of like french cleats on a single point basis.
>Suggest you drill a slant hole from the center of the top end into the back surface, then make a jump ring to take or tie to the rosary chain.
You can also do a disguised loop by doing a wrap of the top branch in say 16ga silver wire to look like rope, then pull a loop in that and epoxy both ends back into your wood.
How about...
John in NM
>A hole with a brass sleeve through it (like K&S tubing from the local hardware or hobby store). You could also make a bail out of brass wire, bend the loose ends at 90 and stick them in a small hole on the back side of the cross, maybe 1/4" or 1/2" down from the top. Then wrap more (and maybe thinner) brass wire around the hole and the bail. I did that to a mallet I made once (wrapped the handle just below the head, no bail on the mallet), both for looks and a little added re-inforcement - though I don't know as it needs the latter.
Thanks - I can get some silver wire.
Thanks - if I can't get the wire, I may try it.
