Restoring a Delta 20" band saw
Bill Tindall, E.TN
>Why restore a large industrial band saw for a home shop? I have had a 14" Powermatic saw for years that I saw curves with, and re-saw a few things like drawer sides. When I took the class at Headley's shop I got to use a machine like this one. Some features like the 14" resaw capacity are obvious but the real advantage for me was the larger table. A band saw with a large table-saw-sized table makes the band saw useful for things I might otherwise do on the table saw and it makes the usual band sawing operations much easier. I expect I will do a lot of ripping on this saw instead of the table saw.
The process: These saws are readily available at surplus auctions and one in restorable condition will be about $600. I paid $550 for this one. It had been in a school. Like all industrial machines, so long as all the parts are there and nothing is broken it is not an expensive job to get one running like new, and new is around $3000. I painted it, replaced all the bearings, cleaned everything, reground the guides and trued the tires. Someone did the tire turning and bearing replacement for me, though having seen it done I could do it next time. Parts and paint cost $90. About 40 hours was spent working on it. Someone more experienced would have taken half as long. I still need to add a fence to the saw and I am still undecided as to what I will do for a fence. The Grizzly looks attractive.
Conclusions: In the end I have a saw as good as new. I can' t over emphasize how nice the large table is for typical band sawing operations. The large wheels means there is less flex on the blade leading to longer blade life. Its size and weight minimize vibrations and it runs very smoothly.
