Performax 10/20
Performax 10/20
Performax 10/20
Jim Hoeller------WebKitFormBoundarycQB+IfmNjFaVxeA
>I have a Performax 10/20 drum sander that has worked very well for several years. Lately the right side of the roll of abrasive has been riding up over the adjacent edge. In addition, the paper has been tearing near the slot on the right that holds it . The drum is parallel to the table based on a test that used an 8 inch wide piece of plywood on which the drum is slowly lowered (feed belt off) until the drum contacts the plywood. The mark on the plywood was the same width from left to right. The rolls of paper are expensive (to me) and I need to find out what the problem is. As far as I know, I have installed the abrasive rolls the same way since it was new. Any assistance would be appreciated. Also, does Performax have a website?
Thanks
Re: Performax 10/20
Re: Performax 10/20
>I have a 16/32 Performax. I assume the clips that hold the sandpaper are Identical. I have the same problems sometimes. Try rolling the sand paper on with a small space between the "rows", about a 1/16" of drum showing. Also, be sire the paper is snug and laying flat on the drum. I find it useful to roll the paper on and lay it on the notch in the drum and then fold a crease in the paper that is about an 1/8 or a 1/16" "short of the slot and then lift the clip fully with one hand and insert the paper through the slot and clip. The trick is to release the clip so that it grabs the paper early and keeps it under tension. There is a gizmo/clip that will hold the clamp for you, but I don't have one.
Jet bought the design from Performax and makes sanders that are very similar (Identical?). You may be able to get more info off their site. They are part of a larger tool group (WMH?) They sold the Performax name and no longer use it.
I also think the paper is expensive. I am considering buying some from Klingspor or even cheaper Industrial Abrasives. It less than half price if you buy it in rolls and cut your own strips. I am about to buy some.
