1/8 lauan board
1/8 lauan board
1/8 lauan board
billy matthews
>I'm building a floating boat house. I have covered my walls and cieling with 1/8 inch lauan board cause it is lighter than sheet rock. I'm trying to hold down on weight. Can you mud and texture lauan
board? If so, how do you treat it? Hoping for advice. BM
Re: 1/8 lauan board
Re: 1/8 lauan board
>We typically use 1/8" lauan board for the sets at our community playhouse. I've mudded it and texturized it quite often. As to how to treat it? We've just typically used latex paint without even a primer.
For a boat house, I'd probably use Kilz or some sort of primer to seal it.
Re: 1/8 lauan board
Re: 1/8 lauan board
>My Experience with drywall is that it is an indoor product and must be kept dry and at a fairly constant temperature. As a Home Inspector I still see it occasionally used as porch ceilings. After a a year or two, the tape and mud fails and the tape falls off. I am sure the industry does not recommend drywall for damp semi-exposed locations. The temperature changes and humidity wreak havoc.
I would think adding a dissimilar material such as luan would make the problems worse. I think it would work just lone enough for you to get it painted and then fail.
Re: 1/8 lauan board
Re: 1/8 lauan board
Pete in Holland, MI
>Would think 1/8" luan would be too flexible for any kind of mudding, both climate changes and bumping into the wall & flexing it. Might be better off cutting 1.5" strips and stripping each joint.
Boat houses can be pretty damp places. Is the adhesive in your luan water/moisture proof?
