THE WOODRAT IS BACK!
Gluing Bloodwood
Gluing Bloodwood
Gluing Bloodwood
Sean Troy
>Is Bloodwood one of those woods that should be wiped down with acetone before gluing because it's one of the oily woods?
Re: Gluing Bloodwood
scottinphoenix
>NO it glues just fine the way it is.
scottinphoenix
>Sean are you the same Sean Troy that was president of a woodturning club in AZ? If so how did all the manzanita roots you bought from me work out?
Sean Troy
>Yes and yes. I turned all those and they sold as fast as I could make them. Wish I kept a few for myself. How are you? It's been a long time. I'm living out in kentucky now.
Ken Platt (granby, CT)
>There was a nice thread on this recently including a very good explanation of why wiping with acetone is a bad idea, and why lightly sanding just prior to glue-up is the way to go.
FWIW, I just glued some bloodwood to maple without any praticular prep and haven't had any problems.....yet.
Ken
Re: Do you mean this one?
Al Stokka - Cambridge, Iowa
>Ken & Sean,
"Subject: NO solvent wash!
Posted By:: Michael Dresdner janeandmichael@msn.com
Date:: Tuesday, 10 February 2009, at 11:28 p.m.
In Response To: Can epi [sic] be glued (Frederick harvie)
Stop and think about this. If you happen to hit the right solvent, one that actually dissolves the resin in the wood (it is resin, by the way, and not oil) all you will be doing will be dissolving said resin and smearing it around on the surface. That is counterproductive and can leave you with even more resin evenly spread on the surface.
The one method that works consistently also has the advantage of being supported by the science behind it. Sand the surface immediately before gluing. Here's why this works:
The problem with very resinous woods is that the resin tends to exude from the wood and collect on the surface. This takes a bit of time, meaning hours or more, but once enough gets onto the surface, it can form a barrier to water based glue, which adheres to the hydroxl groups on the surface of the wood. As long as there are bonding sites on the surface, what is happening below, deeper into the wood, is irrelevant. Cutting or sanding the wood leaves it a clean, cellulose heavy surface -- something glue can grab on to. There may be lots of resin down below, but it does not matter, because once that glue cures, the resin can not exude through it nor dissolve it to weaken its bond.
Thus, if you sand the wood, even lightly, just before glue up, that is all you need do and you will get a very good bond.
By the way, we luthiers (former luthier, in my case) have known this for generations because we've long worked with very resinous woods."
Al
