Finish for plywood work table (NOT mine!)?
Dominic in Bucks County PA
>Hi gang,
Since everyone here at work knows that I'm a wood worker, I've been asked for some assistance.
There is a HUGE plywood layout table that is used in the plant. This table is 16'-8" long x 4'-4" wide. The workers lay out fabric (of varying types and thickness) and then staple the material down so they can mark the fabic for gluing.
Personally, I HATE the fact that they use staples. And on plywood it's even worse. But until I come up with something better I need to work with what they have in place.
I was wondering what kind of finsih to recommend. They need something durable, easily renewed, and that can take the abuse of stapling.
I think shellac would be perfect. However, I not sure polyurethane would be bad either.
Any help?
See ya around,
Dominic
Re: Finish for plywood work table (NOT mine!)?
>My preference would be for a polyurethane spar varnish. Lots of solids to cover up the imperfections in the plywood (and minimize splinters), relatively inexpensive and easy to apply. You can get a gallon can and that should do it for many coats - and have enough to put in a smaller container for touch-up.
GalenV in Iowa
>Since you say the fabric can vary I had just wondered if they want a smooth slick surface for spreading out fabric or something that offers some texture to prevent fabric from sliding? They may have just worked with what they had but they may find a change as better.
Add a layer of homosote board on top as a sacrificial layer that is replaceable and offers some surface texture?
Always a good idea to ask those who use it.
Galen
>You wrote:
"Since you say the fabric can vary I had just wondered if they want a smooth slick surface for spreading out fabric or something that offers some texture to prevent fabric from sliding? They may have just worked with what they had but they may find a change as better.
Always a good idea to ask those who use it."
Thanks for your response. They already have the plywood in place and are not very receptive to adding a sacrificial surface on top of that. And I have been informed that a smooth surface is what they are after.
Re: The beauty of shellac
Glenn Madsen near San Francisco
>Besides the visual beauty, which may not count for anything:
Shellac coats and dries quickly. A coat, wiped on, takes maybe 30 minutes to dry. Poly, somewhat longer.
Shellac need not be sanded for another coat. Poly should be.
Shellac is non-toxic, and safe as a food additive, although you likely won't be using food grade materials. Poly, not so much so.
Can you tell why I use shellac?
Behr one part water borne epoxy
>Garage floor paint.
Clint
Fred Davis
>If expense is not a problem, a smooth Kitchen grade carpet , about a 1/4" thick will never wear our , hold the staples and be splinter free, glaziers use it on their work tables all of the time.
FredD
Re: Finish for plywood work table (NOT mine!)? *LINK*
Bruce, a MN Galoot
>I just happened to be reading the West System EpoxyWorks online newsletter. Go here and check out one of their epoxy coatings. It might be what you're looking for.
EpoxyWorks
