Re: Here's what I'd do...
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Ellis, I'll bet you would run the grain on those short pieces along a line which would connect the toe of each miter, rather than vertical, if that is what the black arrows represent.
If you choose to use more parts. What I normally do, is start by making a mdf pattern. Then after choosing my stock, and having a known width for each part, I might lay those parts on the pattern, which will show where the joints need to be to get the yield.
As for the angle, I don't think there is a magic bullet. when you choose where the joints will be, make the cuts perpendicular to a tangent to that point. You can then cut your pattern apart and transfer that onto your stock, to know where to make the cuts and find the angel there.
After you cut the miters on the lumber. I usually then make a cut a V notch on the toe end of the parts, with one side of the V parallel to the miter. This makes a nice tab on each piece to clamp the outer edges together at glue-up. Then a pipe clamp across the bottom will close the heel of the miters. Then cut the final shape out of the glue-up after the cure.
