New life to an old bench grinder
Chuck in ND
>I know this isn't woodworking, but I'd think that every shop has one. I recently bought an old Dayton 1Z707, 8", 3/4 hp, 8.2 amp, 3450 rpm, bench grinder, and just finished cleaning it up the other day. The jacket of the electrical cord going into the base was frayed, so I snipped that off and rewired the the switch, on the other end someone had cut the ground prong off of the plug end, so I replaced the plug. Next I ground the tool rest surfaces and bead blasted the tool rests and mounting hardware. One of the spark arrestors was missing on the top right hand wheel cover, so I made two new ones so they would match, at first I thought that cuting a 5/16" X 1 1/4" bolt slot was going to be tough to do and look proffessional, but I got it after alot of thinking and planning. Then I scuffed the paint up on the grinder and repainted it, the color is Rustoleum Smoke Gray. It was missing the eye sheilds, so I got lucky and the eye shields and mounting hardware from the grinder this one is replaceing fit like a glove with no modifactions what so ever. This is one heavy, and heavy duty bench grinder. I also learned that Dayton is affiliated with Grainger.
