Finishing Oak flooring questions
>I have rough sanded and repaired an oak floor for my cousin. We rearranged walls and rooms and I patched the places left in the floor including about 200sf of new flooring added in where rooms were moved.
I used a drum sander to rough and medium sand the floor and bring it all to the same level. Then we stopped that and went on with drywall, painting and trim, etc. Now the plan is to use one of the U-Sand units that has the four random orbital sanders built in to fine sand and then finish.
I know some people think the U-Sand is slow, but it seems it would do a good job on the fine sanding step. Any suggestions on that?
And, Any suggestions for finish? I think it will be natural (not stained) and the floor is Red Oak. I was thinking Zinsser Seal Coat shellac with top coats of some type of Urethane. Any suggestions would be appreciated.
Re: Finishing Oak flooring questions
>Skip the shellac. Benjamin Moore water borne poly floor finish will do the job.
Clint
Bart Goldberg
Bart Goldberg
>I agree - skip the Shellac - No Need. One other option for the final flooring finish is Waterlox - I think it may be more expensive than poly, but on the other hand - it is a easily repairable finish and looks great when used for furniture finishing - They sell it in large containers for floor finishing.
Good Luck
Bart
Fred Davis
>Barry, you have been around long enough to remember that Shellac was and in some places still is , the traditional hardwood floor finish.
Absolutely nothing wrong with using it, for a couple of reasons.
You can't get in trouble trying for a nice level finish.
Unlike some water based finishes I have seen stripped off and done over because of lap marks left by the squeegee they used to put it on with.
Also the Swedes have a excellent solvent based finish called Glitza that is a very hard finish put on over a special prime coat and easily repairable with a spray can of touch up they furnish.
Their are no finishes made that are scratch and ding proof , but many are next to impossible to make bonding repairs in.
That would not be the case with Shellac or Glitza.
In addition on natural Red Oak , you get a warmth and color with Shellac that is beautiful to behold.
So, long story short , if you use Shellac under Urethane then you lose the repairability of it.
Straight Shellac or Glitza has advantages that so far water borne finish has not.
FredD
