Cutting glass ...help!
Mike Jones, Redding, CA
>The only way that I can rectify a screw-up will be to cut 1/2" off the edge of a 1/4" plate glass sheet 22" long. I've cut glass before, and have a cutter, but I am not at all sure how to ensure a clean cut of a small strip. Any suggestions?
Re: Cutting glass ...help!
David Yoho
>If you don't feel comfortable about making this cut in fear of a problem, maybe you should see what a glass shop would charge to do it. I wouldn't think it would be enough not to go that route and they could also smooth the cut edge for you.
You didn't say but in case this is tempered glass, it's too late - you can't cut it after tempering.
David
Ralph Lipeles
>If you have a glass cutter that will put down a nicely scratched line and you have the skill to use it, the rest is easy. After the scratch is made turn the glass over. Start tapping along the line with the other end of the glass cutter. After a while you will see the crack begin to develop and move. Keep tapping until the crack is complete, end to end and top to bottom. Be patient. It can take a few minutes. When the crack is fully where it should be, you should be able to lift away the scrap piece.
Baker Glass in El Paso . . .
steve mackay
>Heck I don't even try it any more. And no matter how out-of-square (yes, I'll admit it !) my frames come out, those guys can put glass in the suckers. I drop off the frames or cases, let THEM make scrap-glass then just pick up ! Actually more cost effective.
Greg
>Be sure to clean it thoroughly first then put down a light film of oil (3 in 1) and then make one run across with the cutter using a straight edge to guide it. You should hear an irritating scratching sound. Then turn over and lightly tap along the line. It should come off cleanly.
Fred Davis
>since they don't give 1/4" plate away , listen to Dave and Greg
FredD
Re: Cutting glass ...Thanks!
>So...the project gets delayed...it'll go to the pros in the morning.
Thanks for all the replys.
Lee Schierer - McKean, PA
>I think my local glass shop charged me less than $5 for making several cuts on a plate glass mirror I was resizing. Far cheaper than a new piece of glass.
Lee
