Thanks and more info. *LINK*
Grant in Iowa
>Thanks for everyones responses and for relating applicable experience. Based on the responses, I plan to reduce my layer thickness to under 3/16", and use thickened epoxy in a heated space for the job. I will probably also do a test glueup with scrap wood before the real deal.
It is true that this type of work can be done with clamps and forms, as I have done that before. I decided it was time to take it to the next level.
I am considering this project a stepping stone to making waterskis, small boats and other more complex projects such as veneering and formed pieces in other materials. All of these aspirations are the real reason I have invested in the vacuum press and bag setup. This will be my first vacuum assisted clamping attempt. Though I have had the pump assembled for about two years now. I have only last week ordered a bag to complete the setup.
I built a venturi type vacuum pump using plans and parts from "Joewoodworker.com". The pump was a big success, and I have played with using visqueen as a bag, which met with only partial success. Too many leaks around the taped seams to be workable for an actual glue-up. It did pull my test parts tightly to the form, however, so I am sure the concept of bending in a bag over a form is sound.
An interesting fact is that 1" of mercury(Hg) of vacuum pressure can create 70 pounds of force when distributed over 1 square foot. This means that my pump, which can deliver up to 28"Hg can deliver nearly a ton of clamping force per square foot...and vacuum does this much more evenly than almost any other solution. All of this also means that the form needs to be very well made.
For anyone interested, I will try to take some photos along the way and may submit them for a Shop Shot or two when I am done. Obviously I am no expert on the process, but sometimes the best time to write a how-to article is when you do it the first time. This approach ensures you don't gloss over necessary details.
By the way, the materials for the vacuum pump cost about $140 or so. I built the "V2plus" venturi pump, designed to be used with a medium to large air compressor. The 4'x 8' bag was about $170 with shipping. Smaller bags are available for much less money if you want to do smaller projects.
If you been interested enough to have read this far, then you might want to head over to the attached link to learn more on the subject than I am qualified to say.
No interest in JoeWoodworker, except that I am vary happy with the service and products. Joe personally answered all of my questions and is a friendly, courteous small business owner. I believe Joe owns both "JoeWoodworker" and "Veneersupplies.com". Lots of good information there.
Regards,
Grant in Iowa
Joe Woodworker
