Electrolysis Improvement
Tom MacGregor
>Since electrolysis used to derust tools tends to be "line of sight" I wondered if it was possible to improve the line. I picked up a salvageable V&B 907C on ebay and wanted to dunk the whole body at once, not my usual flip-it-in-the-bucket routine. I bought a cheap (under $5) plastic trough for soaking wallpaper long enough to immerse an object up to 30 inches long. A short chunk of sacrificial iron concentrated the rust removal on less than 1/4 of the plane body. I took a 5-1/2 foot long piece of 1/4 inch iron rod and bent it into a long U around the trough and hooked it up as shown below. I got bubbles the full length of both sides of the plane! I will note, however, that it's very easy to make a BIG mess if you're not careful dumping the liquid out of the trough. Please DAMHIKT.
Re: Electrolysis Improvement
And thou shall not let plane touch the rod!
Art Silva
Nice! The mess part reminded me of the time I was electroplating a railroad spike with copper in a glass quart jar, set up on my mother's card table. Everything was going well until I dropped the spike and broke the jar!
Can you give some details on the process, i.e., what electrolyte, voltage and current?
R Drouare
>What does "DAMHIKT" mean?
Thanks ---Ralph
Tom MacGregor
>The electrolyte is one heaping tablespoon per gallon of water of Arm & Hammer Washing Soda. It's made of sodium carbonate. It's hooked up to an automotive 12 volt battery charger - negative to the object to be derusted and positive to the iron rod. My charger is switchable between 2 or 10 amps. I run it at 10 amps because it's faster, but 2 amps will still work.
Don't Ask Me How I Know That
Tom MacGregor
Jim Pugh, Elyria, OH
>For what it's worth, you can derust any steel part by soaking it in grocery store grade vinegar. Usually overnight will do the trick. Once you rinse the vinegar off you have to oil the item or do something else to coat it or it will start rusting again.
OK, you guys, a question or two....
>I am thinking the vinegar would take the rust off, leaving you with a clean but pitted piece. (right?)
Does the electrolysis actually replace the rust or reverse the oxidation process and put the iron back into place? If it does not repair the steel, why bother?
check my article in Articles for answers
Bill Tindall, E.TN
Re: check my article in Articles for answers
>Thanks Bill. I gather that you really can't replace the Iron. I was excited about the idea of building up the surface and restoring rusted items. Now that I think about it more, it would be necessary to re-mill the pieces even if you could, because you have little or no control over where the new iron was deposited. And then there would be "alloy" problems.
historical perspective
Bill Tindall, E.TN
>Before it became the museum fashion to not irreversibly alter anything in conservation, electrolysis was the preferred means for de-rusting and stabilizing iron objects. For one thing the metal was left with a somewhat protective, and attractive, surface of stable iron oxide, formed from the rust. In the case of iron recovered from sea water, electrolysis was the only way to get chloride out of the metal. Electrolysis migrated the chloride from within the metal into the bath. Any chloride left in the iron would promote further corrosion.
Additionally, electrolysis is good at blasting loose stuff from the object. Electrolysis will not only remove loose rust but also paint, grease etc, something acetic acid will not do.
Acetic acid will dissolve the iron oxide formed by corrosion. But it will also dissolve the iron too, so leaving things to soak too long must be avoided.
For anodes, a stainless steel screen from the junk yard works great. It can be wrapped around the object and the solution moves through it unhindered.
