Ceramic Tile Inlay
Ceramic Tile Inlay
Ceramic Tile Inlay
Hal B.
>I'm making a small box (5x5") with a recess in the top to hold an Arts & Crafts ceramic tile (4x4") that someone had given to me. I plan to glue the tile to birch-ply which forms the bottom of the recess.
I'm wondering if I have to use tile setting mastic (which I don't have) to glue the tile, or can I use Titebond or Gorilla glue?
Thanks for your advice.
Re: Ceramic Tile Inlay
Justin Szeliga
>Just about any caulk will do, silicone works well in an application like this.
Peace
Justin
>I like PL Poly Construction Adhesive, but agree with the post above.
Clint
Kevin H.
>Clear silicone... permanantly flexible, excellent adhesion.
Caulking... not as flexible, adhesion OK, but not as good.
Mastic or thinsets... not flexible to deal with expansion and contraction of wood.
Fred Davis
>Hal, get a caulking tube of PolySeamSeal, a adhesive caulk that does everything Silicone does , only better and it cleans up easily with water.
Comes in White, off white , colors and Clear, your choice.
One caveat about this product , avoid sticking anything together , that you may want to move or remove at a later date.
FredD
