Japanese Water Stones
Paul Storck
>Unfortunately I have grooves in my water stone from sparpening knife blades. I need a level surface to sharpen my chisel blades. What is the best way to level the surface of a water stone.
Paul Storck
Re: Japanese Water Stones
Dan Donaldson
>You can use sandpaper, carbide dust on cast iron, diamond plates, basically most anything that is flat and abrasive. (even other stones. You need 3 to get flat) Also, what is your definition of "grooves"? If you mean hollows in the stones then the above should get you started. If it is actual narrow grooves in the stone, it may not be necessary to get rid of them completely. As long as there is a flat surface across the stone, it will still work OK.
Re: Japanese Water Stones *LINK*
Hal B.
>I've flattened waterstones in two ways. If you have a truly flat surface, like a chunk of smooth granite or a sheet of leaded glass, you can glue sheets of sand paper of increasing grits to these flat surfaces, and then run the stone across each sheet in succession, making sure to remove the grooves from one grit with the next finer grit. Similar to the method sometimes used for sharpening edge tools without stones.
The alternative is to invest in a flattening stone. Norton makes the one I have. Here's a link to an example, but you should shop around for price (DISCLAIMER: I have no financial ties to Rockler):
Example of flattening stone
Dick Coers
>I have used two methods, put a piece of course drywall sanding screen on a piece of 1/4" thick glass, second method; very course diamond stone. Guess which one is cheaper? Use plenty of water to wash away the slurry. I usually reserve the sides of the water stone for card scrapers or narrow tools that can groove the stone.
>I was given a Norton Flattening Stone (actually I was given two). It works well.
Before I had one, I used a glass plate and 80 grit silicon carbide powder. Sprinkle the powder on the plate, add a few drops of water to make a slurry and make figure 8s with the stone.
Paul Storck
>I want to thank you all for your insites and quick responses. It looks like I have a lot of options, but I'm sure I'll find one that will work.
