ADVERTISE HERE - FREE TRIAL
OT- 1x1 mesh tile backsplash - notch or V trowel?
Steve Silca
>I'm installing a 1x1 mesh tile (12" squares) this evening and wondering if you would recommend using a 1/4" x 1/4" notched trowel to allow myself a little more play in the installation, or a V-notch trowel to avoid the mortar leaking through the grout lines.
Any advice/testimonials appreciated!
SS
Re: OT- 1x1 mesh tile backsplash - notch or V trowel?
Jon Weisenbach
>Probably the v-notch will do the trick just fine. I assume your using mastic rather than thin set but either system will work with the v-notch.
Jon
Jon Weisenbach
>Should have added the square notch would probably tend to leave too much adhesive as apposed to the v-notch.
Jon
