OT Timer switch
OT Timer switch
OT Timer switch
Frank Orfanello
>SWMBO has taken up glass fusing as a hobby and looking at some of her work I think it might end up incorporated into a woodworking project some day but here's my question.
She has a kiln that plugs in to a 110 outlet, and has a rocker switch built into the cord. She has to turn on the rocker switch for a certian amount of time which varies from about 15min to about 1hr depending on the effect she is trying to get. She knows how long it needs to be set for each time, so its not a random event. Currently she has to turn it on and then either stay and wait for the elapsed time, or remember to come back in time to shut it off. With kids and cats and dog (but never because of husband!) sometimes she looses track of time and the piece gets ruined, 2 or 3 minutes too long and goodby.
Does anybody know where I could find a simple timer switch that I could plug in between the kiln and the wall that would shut off the power after the set time has elapsed? I can find all sorts of switched that would allow you to set a timer for multiple ons and offs during a day but nothing that would just shut off after a set time.
Thanks
Frank
Re: OT Timer switch
Darkroom Timer
Marvin Horn
>My first thought was a darkroom timer, just what you need. Did a quick Google search and boy has their cost gone up since my phototography days. Maybe you can pick one up used on eBay.
Re: OT Timer switch
Re: OT Timer switch
Bill Earl
>What are the current requirements of the kiln? As I recall, the big GraLab darkroom timers are only rated for 5 amps.
Re: OT Timer switch
Heavy Duty On-Off Switch
Al Goldstein
>Frank,
For times less than one hour and if the kiln draws a lot of current, then you need an industrial timer with sufficient accuracy. However, for times of approximately one hour or greater then you might get by with an On-Off timer with high current capacity that you can buy at any hardware store. Simply throw away the On tab and just use the Off tab. Set the Off tab at any hour. Then rotate the time dial to a time before the off-time so that their time difference is the required kiln on-time. For example, if you want the kiln to be on for one hour then set the Off-tab to 6 PM and rotate the time dial to 5 PM and plug the On-Off switch into the wall. After one hour the kiln will be turned off.
The downside to this simple technique is that it is difficult to set the required on-time with accuracy. However, I use such a On-Off switch when I am charging my cordless batteries. I've heard of several fires caused by the overheating of charging cordless batteries. By setting up my On-Off switch to only power the charger for several hours I get a full charge on the battery while minimizing the danger of it overheating.
Good luck.
Al
Re: OT Timer switch
Re: OT Timer switch
GalenV in Iowa
>Kiln on 120 volt must be small. Look at the simple Paragon type SWP mechanical timers. They are the type you use for like a bathroom heater or spa. They are rated for like 20 amp. You would have to be sure of the range as maybe a 60 minute may have like 5 minute minimum setting but look for on line and see what range best fits.
Galen
Re: OT Timer switch
Re: OT Timer switch
Tom Dunlap
>There are switches that can be hard wired into the wall circuits that have high amp ratings.
One that I have has a ring with slots in it that can be filled with metal tabs to turn the switch on and off in fifteen minute increments in a 24 hour cycle. I sourced it from a greenhouse supply company. They're used to turn on lights to simulate varying daylight lengths to force flowering. There are also ones that are hourly that can be set in minute increments for mist benches.
I used mine as a switch to turn on six engine block heaters for vehicles when I lived in Minneapolis. The timers would come on about 2.5 hours before the crew showed up. The engines were all warm and they'd start easily.
Graingers would be a common source.
Re: OT Timer switch
Re: OT Timer switch
Curly Smith
>How about a bathroom fan timer?
Intermatic 60 Minute Spring Wound Timer
Time limits of 5, 15, 30 and 60 minutes and 2, 4, 6 and 12 hours are available
Re: OT Timer switch
Intermatic, Paragon, Leviton all are similar
GalenV in Iowa
Re: OT Timer switch
Re: Darkroom Timer
Frank Orfanello
>Thanks Marvin I look at them.
Re: OT Timer switch
Re: OT Timer switch
Frank Orfanello
>Bill,
I'm not sure exactly, but it's not more than 15 amps. I do think its more than 5 though.
Re: OT Timer switch
Re: Heavy Duty On-Off Switch
Frank Orfanello
>Thanks Al.
I need less than an hour most of the time. I tried your method aready and as you surmised less than an hour is a problem.
Thanks anyway.
Re: OT Timer switch
Re: OT Timer switch
Frank Orfanello
>Curly,
That's a good idea, I could wire up a box with this in it and a 110 outlet. I'm still looking to see if there is something that would just plug into an outlet and have a receptecle to plug the kiln into it.
Thanks
Re: OT Timer switch
Re: OT Timer switch
Charlie Self
>I used to have a water heater timer around here. I think they still make them: it wasn't expensive, but it was hard wired, too. I can't recall the maker. It would be easy enough to wire it into the middle of a short, heavy duty extension cord.
Re: OT Timer switch
Re: OT Timer switch
GalenV in Iowa
>The mechanical spring timer for bath heaters/vent fans is probably the cheapest you can buy for higher load. They do normally have a 10 minute minimum setting but how long do you have to add in to bring kiln up to temp?
We used a lot of industrial timers but this would require putting in a box of some type. Not sure what you may be able to find for surplus timers in your area. The Eagle Signal timer in the old HP5 series I know has a 60 minute with like 2 minute minimum setting increments. ATC and OMRON make them too. Some are for panel cutout, din rail mounted or octal base. Then you get into even more expensive digital electronics. They would be more direct time setting wth a dial.
Not sure how much you tinker with things but older microwave ovens had mechanical timers that you could probably adapt. Maybe an appliance store has some old equipment you may be able to find a timer for your cost to remove.
I don't think many 12 and 24 hour muti-setpoint timers will give you an easy way to set time down to minutes. Defrost times generally are set timers in a long period.
Your better half can just set you in the corner for an hour or less to watch! :>)
Galen
Re: OT Timer switch
Re: OT Timer switch
Frank Orfanello
>Thanks everyone for your great ideas. This place is a fountain of knowledge!!
