We value your privacy.
>I just lost an old American Holly tree and I wondered in the wood was useful for furniture building or for turning. I seem to remember reading about using it as an inlay but I don't know where I read it. The grain is very close and it is very hard but the branched and trunks are not straight so getting many planks out is a problem. Thanks for the help.
>Holly is hard to dry. Do not try to dry it in log form or it will bust. Slab into planks, dip in Chlorox to sterilze and get the surface dry quickly. It will mold and stain readily. If you live where it is still cold, begin drying it where it stays cold. Once the surface is dry it is less likely to get stained from mold as it continues to dry.
Because it is very dense and very white it is useful for inlay, banding, knobs, handles, decorative turning and all sorts of useful items.
>Put up to dry while it's cold, blue-gray mold/fungus does not have the temp to grow. Never have heard of bleaching to stop the discoloring, in holly, may work, just have not heard of it. The key is to get the wood's surface, the shell dry before warm weather returns, 50*F+.
>A friend gave me a rather large holly tree trunk which I sawed into planks with my chainsaw. Powder post beetles promptly ruined it after that. Seemed like the wood was really prone to infestation as they did not bother the other wood in the shed. Holly makes nice inlay.
>Teak and Holly used to be the primo flooring material for yachts. Thin strips of Holly were laid between wider strips of teak. the holly was slightly raised, since it is harder and takes the wear. You can buy a sheet of marine ply with a teak and holly veneer for about the price of a boat with an ordinary floor. Jerry Gibbs
>If kept pristine -- which isn't easy, as described by others here -- holly is a lovely, very white wood, although, I suppose because of its shrinkage characteristics -- it has one of the most pronounced shrinkage differentials between radial and tangential grain -- it isn't commonly seen in furniture or cabinetry, with the exception of stringing and inlay on period pieces and new construction. I personally love it for turning, as the shavings peel off like butter.
>Search the Turning board for recent threads about holly. Bottom line seems to be holly will either stay white, stain, or discolor depending on unknown factors - you just cut it and wait and see. I've had some stay pure white, some turn ugly gray, and some get a partial greenish cast.
It can warp significantly as it dries.
Holly is a wonderful wood for turning - fine grain, takes finish well. When I use Myland's friction polish it looks a lot like ivory. I have a bunch of turning blanks drying right now, leaning up against the wall behind my woodburning stove.
>Some harpsichord makers use it for jack tongues, when they can find it in good condition.
Once well seasoned, it is stable in shape, workable with precision, and resistant to splitting. Jack tongues are usually quarter sawn, and radial expansion is allowed for in the design.
>When I visited Virgil,s home & shop a number of years ago, he graciously gave me a piece of his holly. I've used it in two projects. One an inlay in a cherry box:
The other was borders for a picture frame.
In both cases I was after the contrast between the darker cherry and the white of the holly.
The wood is easy to work with. I still have some pieces left over. I have noted that some of the strips that I cut from the original board have bowed as they have continued to dry.
>I've bought dried holly and used it to make small to medium boxes. Use walnut or cherry to highligh the holly at it looks great. No problems with warping or finish.
>Someone gave me the powder post beetle infested holly.
I cut some that was very thin and sanded it to .02" with my drum sander. Used it to make a lamp shade. Throws very interesting patterns on the walls. May make door panels out of it one day.
