Tempered Glass in Curio?
JohnM in Mid Mich
>Should I use tempered glass in doors and sides of a curio cabinet, or can I justify using cheaper un-tempered? Thoughts?
JohnM in Mid Mich
Re: Tempered Glass in Curio?
Lee Schierer - McKean, PA
>You can certainly use tempered glass in your curio, but most people use regular glass. If you have a home with small children tempered might make sense from a cost standpoint as it is a bit tougher and breaks more safely than regular glass. Normally temered glass is used in doors people go through as they might run into the glass and break it.
Lee
GalenV in Iowa
>Do they even sell single strength glass anymore? I wanted a large piece of double strength for a large gun case. Double strength probably standard by now? Even at that I just about had to sign my life away as the supplier said they normally assume large sheets are for doors or windows and sell tempered only in large sizes.
It has been a while since the purchase so wondered what the latest info on types that can be purchased?
Galen
>You can still get single strength glass. The law doesn't allow tehm to sell regular glass for entry doors. For larger pieces, your best bet is to take your project door to them and let them measure and fit the glass. This avoids the needless discussions and they assume the reponsibility that the glass will fit properly.
Lee
I agree with Lee
>It depends on how close to the floor it is and how many kids are ever in your house. If it's anywhere near where a child can reach it, you bet it will get broken.
>If you decide to go with tempered remember, measure twice, order once. Once you get the glass there ain't no trimmin' it!
Tom
Yeah Tommy, And that Can Be A Real Pane
Fred Davis
>Using the UBC guideline of any glass in doors,shower doors or windows or fixed cabinets within 18 inches of the floor , it will either be shielded with grill work or tempered.
Any jurisdiction I did work in insisted on the tempered for safety reasons.
Obviously this didn't apply to furniture, but the safety concern dictating it still makes sense for other applications.
If you go with tempered , it has to be cut to size before it goes though the heating process that tempers it, it can't be cut afterwards.
FredD
Re: Tempered Glass in Curio? *LINK*
Robert Lemon - Sacramento CA
>John, you might want to check out this site for more information on glass and how much it could cost you.
http://www.pecoglassbending.com/
Doug Reynolds in Seattle
>I am making a set of four barrister bookcases for my daughter who wants to go to law school. I opted for annealed glass. Annealed glass breaks into shards i.e., knife-sized pieces but, it will crack first (sometimes) and give you a little warning. Tempered glass crumbles which makes it safer to be around when it breaks but, does not crack and give any warning. I don't believe there is a significant difference in strength. In Seattle, the difference in cost for a 2'X 2' X 1/8 inch annealed ($21) and tempered ($28)or, about $8. For applications where safety and security would be an issue I would recommend laminated glass which would only cost about $50 for the same 2' x 2'.
What about lamminated glass?
Gary Camp, Bend, oregon
>I always use lammi when a safety glass is required. I breaks in big pieces like "regular" glass, but the plastic layer keeps it together. I don't end up with an empty hole and ten thousand pea sized pieces to clean up.
glc
Thanks all.
JohnM in Mid Mich
>So, I might see what the cost differential works out to, and let that be my guide. I sort of like the idea of letting the glass shop install. The doors would be easy to move, but for the sides I'd be hauling the whole darned cabinet, putting the glass at that much more risk. Thanks.
John
