removing paraffin sealer
Jim Follette...Fayetteville, NY
>What is the best way people have found to get the paraffin sealer off wood blocks? Got some neat exotic sticks from WestPenn to incorporate into cutting boards.
Thanx.
Re: removing paraffin sealer
>Hate to say it, but cutting it off would be what I'd try. I'd be afraid of a solvent carrying the wax into the wood if it is open grained. Exotics and other blanks intended for woodturning are almost always coated with wax but it is turned away.
Note that the wax is to keep the wood from drying, or at least from drying too fast, so your blocks may still be wet inside, especially if new and thicker than pen blanks.
>I scrape most of the wax off. I then cut or trim the wax sealed ends.
Like John said, I'd be afraid of solvents and wax migrating into the wood (and interfering with a finish). I would also not recommend using heat as that can drive the wax further into the wood (DAMHIKT).
Plane them off
Ellis Walentine, Host
>Hi Jim,
I'd echo the concerns expressed here. Heat and solvents are not a good idea. A hand plane should make short work of the wax, though. There will be traces of wax left after planing, but you should be able to wipe them down with acetone or naphtha to get rid of them prior to glue-up.
A hand scraper should also do the trick, followed by your choice of flattening/dimensioning machines or tools.
No easy way out. Be careful of wood moisture, too. The wax is usually intended to keep it in.
Thanks
Jim Follette in Fayetteville, NY
>Hi Ellis,
I guess I better let the sticks equilibrate a while after I get the wax off, prior to final machining and gluing.
Jim
Fred Davis
>I don't know the size of your blocks , but a night in the freezer will speed up taking it off.
FredD
Re: Plane them off------WebKitFormBoundaryAATtAA88
Jim Follette...Fayetteville,NY------WebKitFormBoun
>Hi Ellis,
Thanks. I guess I also need to let the sticks equilibrate a while after the wax is off before final machining and glue up.
------WebKitFormBoundaryAATtAA88AA4+AAFc
