Using toner to repair sun fade on cabinets
Joe Pack
>With the help of a guy in Mississippi who has a treasure trove of discontinued Amerock hardware, and with the discovery of a "miracle product" called Restor-A-Finish, I have taken care of most of my kitchen cabinet problems and my sweetheart is happy again. I still have one problem, though, that annoys me more than it does her...the clouding/whitening of the laquer finish on two lower cabinet doors.
I know the problem comes from sunlight because as I was working on my cabinets at exactly the right time of day, I noticed that the bright sunlight coming through the kitchen bay window shown brightly on exactly the cloudy/white areas of the cabinet. The sunlight was at exactly the same 25 degree angle as the cloudy area; where the bright sun was striking was exactly the area where the finish is cloudy.
What I need to do now is to try to "tone" the cloudy/whitened area to match the area that has not been sun damaged. I have absolutely no experience at this, so I am looking for suggestions. I don't mind trying just about anything myself, but am also not too proud to go to a pro if I am getting in over my head.
I am looking for two things...(1) how to proceed on my own (2) where to look for professional help. I am in north central Ohio if that rings a bell of any pros I can trust.
Re: Using toner to repair sun fade on cabinets
Trade-offs
Ellis Walentine, Host
>There are usually a couple alternatives to solving a problem like this, Joe. I'd say my first instinct would be to sand through the oxidized wood tissue and refinish. If you put toner on a finished panel or door it will just sit there -- no penetration, just coloring -- and you'll have to spend precious time getting the color right and blending it just so. When you're done with all of that, you'll have to topcoat anyhow, to keep the color under cover.
Sand and refinish is my recommendation, even if it means doing all the doors. Also, depending on the dye stains you might be using, you might want to try a top coat with UV resistant additives.
Fred Davis
>Joe , try misting the aea with Lacquer thinner or alcohol, just in case you may have some moisture migration.
If it is sunlight , you still may get a acceptable look without messing with the finish more then you need to.
FredD
>Good Evening Joe,
I've had to restore several cabinets in clients' kitchens. What Ellis said is surely true, and it may come to a complete refinish job on all doors. However, I've gotten lucky several times and was able with some fussing and tantrums, to achieve an acceptale match between a new finish on bad doors and the original finish. Experiment.
George
won't fix problem
Bill Tindall, E.TN
>If the problem is as you state it, namely the finish has turned white from sun exposure, it means that the lacquer has been decomposed by the light. Decomposed means that it no longer has the mechanical and optical properties of the original finish. It shot! Covering it up with color is not going to fix the problem, nor is reconsolidating the finish with lacquer solvent, nor recoating with fresh lacquer. You need to get the decomposed finish off the wood and recoat.
However, in my experience, lacquer turning white is caused by water exposure, such as steam leaks from a dishwasher. In this case the lacquer is crazed but not decomposed. Spraying with a slow evaporating lacquer solvent will renew the finish.
>Joe,
Have to vote with Ellis here. Since you've been able to isolate the cause, sunlight, there's little point in trying to redissolve the existing finish to release water vapor that's not there. Given the sun exposure on your cherry, you should be prepared for the wood under that damaged finish to darker that the rest of the door, being as how cherry is photosensitive and darkens with UV exposure. I think you're better advised to sand the entire door surface to see where that takes you. You haven't mentioned whether your doors are solid or veneered which makes a difference in how deep you can sand, of course.
Once you get the finish off and see what you've got to work with, you will be better able to decide on the next step. Paradoxically, you might have to consider lightening the effected area to get it to match the rest of the wood.
Good luck and post a pic or two.
I think you are reading this wrong *LINK*
Michael Dresdner
>If I am not mistaken, you may have a far simpler fix than anyone here has suggested.
Lacquer, if that is what is actually on your cabinets, does not turn white because of sunlight exposure. In fact, it gets more amber with exposure to sunlight.
However, there are two things that can happen with lacquer to make it turn white that can be exacerbated by sunlight, which might account for why it is happening only in the sunlight bathed sections. The sun can warm the wood and lacquer enough so that moisture will move into the lacquer, creating a white blush, or the sun can degrade the lacquer to wood interface, causing delamination, which also looks white. Both can be fixed by spraying the area with amalgamator, lacquer retarder, or the easiest of the three, Blush Eraser, which you can get at most woodworking specialty stores in an aerosol can.
None of these will preclude any of the more draconian fixes suggested, so I would advise you to try them first.
Blush Eraser
As Adrian Monk says, Maybe, but I don't think so
Joe Pack
>The doors in question are the farthest away from the sink and the dishwasher, but they are above a heat vent. I thought for some time that the heat was the culprit, but changed my mind when I was just standing there, staring at the whitish color. As I stood there staring, the sun came out brightly and shone directly on the doors. The sunlight ran on an angle from 10:00 to 4:00 exactly on the good/damaged border and all the way to the right to the fridge. The area where the door handle caused a shadow (a 4:00 shadow) is not white like the rest; the area protected from the sun is fine on both doors.
At that, it does appear that my only option is to refinish, but I may just live with it. Matching everything else may be next to impossible, then only be short-lived when the cherry starts to darken again.
Thanks for the input. I appreciate it.
Affected doors are solid
Joe Pack
>The doors are solid, so removing the finish is possible.
Thanks Michael
Joe Pack
>Thanks Michael. I'll give the Blush Eraser a try before I do anything else. I have very little to lose by trying this first.
Thanks to all
Joe Pack
>Thanks for all your advise. I really do appreciate it. If anything positive happens with this problem, I'll let you know.
