Inverter question
Inverter question
Inverter question
Malcolm Timbers
>I want to use my desktop computer and printer in my RV this summer. A solar supply store guy told me that a computer printer won't work on a square wave inverter. He said I need to buy a sine wave inverter @ $350.00. Is that true.
I tried my old printer on my regular inverter but the printer isn't printing and when I tried it on house current, I find there is something wrong with the print head since I haven't used the printer in several months. Or did I damage it by plugging it into a square wave inverter? I am on the road, actually a camp site in Arizona, right now, so I can't reall do a whole lot about the printer problem from here.
Re: Inverter question
A Wright
>What is the power input to the printer?
I have an HP inkjet printer that accepts a DC power input (there is an AC to DC conversion "box" in the middle of the power cord).
I also have a Brother laser printer, and it uses AC power (and a lot of it). I actually had to put it on a seperate breaker in my office because the current draw was 13A, and everytime the printer came on it caused the lights to dim a little bit while it warmed up (it was on a 15A breaker)
If your printer has a DC power input then I don't know why there would any problem.
Curly Smith
>Your electronics will require at least a modified sine wave inverter. They may, or may not, require a pure sine wave but a square wave will not work in most cases.
One possible alternative: If you already have a UPS then you might be able to connect it to the existing square wave inverter and let it generate a modified sine wave. If you have to buy the UPS then the sine wave inverter might be a cheaper alternative.
If your printer is an inkjet printer then my initial guess is a clogged printer head.
Bill Howatt
>It's hard to say whether or not you damaged it but they normally say that electronic equipment should have a sine wave with less than 5% THD (total harmonic distortion). A square wave would be a lot more than that.
Bill
Pat Evans
>We use a square wave inverter in our RV and it runs our LCD tv, DVD player, two computers, and camera battery charger. However, we also have a battery charger for a rechargeable flashlight that won't work on the inverter. You might try contacting the printer manufacturer. I know that's iffy at best, but maybe you'll get lucky.
