Lockset Jig
Lockset Jig
Lockset Jig
Jerry Nicholson
>I will be finishing and installing 7 new mahogany panel doors in my house and would like to know where I can get a lockset jig. I can't find it at the usual suspects such as Rocker and Woodcraft.
Jerry
Re: Lockset Jig
Re: Lockset Jig
steve mackay
>Don't the Borgs sell lock / jig / saw outfits all in one kit ?
Re: Lockset Jig
Indeed
>The "jig" is often a paper template that folds to fit over the door, but I would think for seven doors, that should be enough.
Drill the main hole from both sides - with a hole saw, you can test whether you're straight by whether the teeth all hit the surface at the same time, and, once you get 1/4" in or so, it guides itself. But, when you see the pilot bit poke out the other side, stop, and drill from that side. As with auger bits and flat bits, you'll get less tearout on the second side that way. Also, a lot of hole saws won't go all the way through a door thickness anyway.
That assumes you're using the modern type of lockset. If you're installing mortise locksets (boxy things that require a similarly boxy mortise in the door edge), that's a whole different conversation.
Re: Lockset Jig
Re: Lockset Jig
Jerry Nicholson
>You are correct! There is a Dewalt unit at Lowes for $29.97 and a much simpler unit at HD for $12.97. I think I would have to order them though. It seems like Rockler used to carry stuff like this.
Jerry
Re: Lockset Jig
Followup
Jerry Nicholson
>Not only does Lowes carry the Dewalt unit but the store second closest to me (there are 4 stores in the Wichita Kansas area) actually has it in stock!
Thanks for the pointer!
Jerry
Re: Lockset Jig
Re: Followup
Fred Davis
>Jerry, I have a Kwikset lock mortising they gave me , when I was doing a lot of subdivision locks.
The large 2 1/8 " bit cost's more then that .
If your in the Wichita area and you don't know of him , contact Dennis Laird for all of your woodworking needs, he manages the Big Tool store in Derby.
Before that he managed Sunflower tool store in Wichita until White Star folded them up.
Even Ellis can tell you about this guy, if his memory hasn't failed him.
Dennis Laird
Big Tool
1-800-788-6505
Tell Dennis I sent you.
FredD
Re: Lockset Jig
Big Tool Store
Jerry Nicholson
>It has been 2 or 3 years since I was in the Big Tool Store - great place but it's about 15 miles away. Lowes built a new store across the highway from Big Tool Store.
I tried to convince them that they should move their store to the west side of Wichita but they didn't think they wanted to do that. Probably a good thing anyway - I tend to buy a bunch of stuff I don't need when I am there.
Jerry
Re: Lockset Jig
Re: Lockset Jig
Roger Lance in GR, Michigan
>Porter Cable at one time sold a number of jigs for door installation....if you still have a major tool dealer in your area that Black and Decker has not as yet run off, check with them.
Re: Lockset Jig
Re: Lockset Jig
mike from american sycamore
>yes porter-cable makes an excellant hinge butt template kit part # 59381 and a lock mortise jig. Most lagre rental yards also rent these for a few doors it might make sense and Black & Decker has not run any PC dealer away that I know of! IMHO B&D buying PC and Delta has been the best thing for both companies and the consumer
Re: Lockset Jig
Re: Lockset Jig
>I'll take you at your word...but in the opinion of many others, the take over of PC and Delta by BD is not the best thing that could have happened to them...not the best thing for the level of quality of their products...and not the best thing for their previously loyal customer base...now thats IMHO...which of course you will honor and respect as I did your point of view.
