Securing bandsaw blades for storage?
>I usually coil them and use twist ties and put them in my saw drawer. As bandsaw blades are sharp and pointy, I sometimes wonder if this is the best way. Anyone have any other alternatives?
Re: Securing bandsaw blades for storage?
slozuke
>I just coil mine up and hang them from a hook in the ceiling above my bandsaw. Nice easy reach when I need one.
>Good Morning JL,
I retain the cardboxes which Suffolk Machinery uses to mail me the blades. After coiling them, I wrap the coils in several sheets of newsprint, and put the band in the box. Actually I use a box with capacity for several blades. Easy to write the blade specs on the box exterior. Thus, if I want an Alternate Set band, eg. I can go to that specific box to get it. The box's can store on handy shelves or racks.
George
Make That Cardboard Box ILO "cardbox"
GalenV in Iowa
>I coil them as you noted and put them in rip-stop mailing envelopes. They are somewhat protected, as never poke through, and then I can label the outside and stack in a box in the cabinet under my bandsaw.
Galen
Lee Schierer - McKean, PA
>I coil mine, secure the coils with a plastic twist lock and hang them from a hook on the peg board that makes up the walls of my shop.
Lee
>Since I never figured out how to fold them back up, I decided that nature never intended that anyway, so they hang from a nail under the stairs.
Clint
JL and Clint
>JL,
I coil and hang, but if this is long term storage you might do what Woodmizer does when shipping a box of 10 blades. They coil, secure with a bit of copper wire, then stack them in a box with a piece of cardboard between each blade.
Clint,
I wish you could stop by for a visit. I can show you how to recoil in about 10 seconds. I once saw a YouTube video and have read instructions on the web, but the way I do it is easier.
I hold the blade with points up about 1/3 of the way down the loop with two hands, thumbs up, secure the loop with my foot where it touches the floor, push my hands together while rotating my wrists so the thumbs point towards each other - this makes a three part "figure eight" where the blade crosses itself twice (1/3 and 2/3rds of the way down), then push the upper loop down in front of me until the blade folds up into three loops. With a large sawmill band I sometimes support the top with my belt until the loops are formed. Coiling a long blade into more than three loops is trickier but not impossible - just do this twice.
BTW, uncoiling a large bandsaw blade can be dangerous since it opens quickly and all at once. The only bandsaw injury I've had since 1968 was when an uncoiling blade bounced and caught me in the forehead. I always use safety glasses and gloves but never thought to wear a full face shield.
Tjhe mere thought of recoiling a long blade
>Makes me recoil. :<)
George
Groan..... (That was bad).
Hmmmm.
>I've got two bandsaws. I usually keep a 1/4" on the 14" and a 3/4" resaw blade on the 18". I use the 14" for cutting curves and the 18" for resawing and making straight cuts. I had an old 1/2" on the 14" cause I was trimming the log splits for spindles and I switched back to the 1/4". That prompted the query. I usually use twist ties to secure the blades. I can always make a small box.
