We value your privacy.
>Depends on what you call flat and how much time you have. If you have plenty of thickness this might be a good way to go, but you will be learning as you go, unless you have a similar scrap to practice on.
Another way to do it is "router rails". Install a shoe on your router with long rails that will support the router. They may need to be more than twice the width of your piece. Then put another set of rails, one on each side of your work piece. With the bit hanging down the correct amount, you slide the router back and forth, cutting off the high spots until you have flattened the entire surface. The rails need to be sturdy enough not to bend and deflect. The work piece and the rails need to be secure enough not to get shifted during the process. Once this is all set up, its faster than it sounds.
>I often do seat blanks (550 x 550 mm) with a hand plane (#5).
I secure the seat blank on the bench with bench dogs on the sides. I then figure how which way the grain is going - you want to plane with the grain at a slightly skewed angle (5-15 degrees). You don't want to plane into the grain as that will raise splinters and rough spots.
An electric plane does work also - but it is noisier. Make sure that you don't take too much of a cut.
Electric hand planes vary in quality and size so it's hard to make a general statement about using them for your purpose. Can you tell us more about your plane? Manufacturer, length, width? Also, if you can tell us more about the surface you are attempting to flatten we might be able to offer some tips. Is this for a dining room table? A potting bench? What kind of wood is it made from? What's the thickness? I know some the Australian woods (timbers?) are very hard and difficult to work. Is that the case here?
It appears that you have no background in woodworking. A trip to the library to get a few books on basic woodworking would be a good place to start.
