I made a steering wheel
Tom Sontag - St. Louis
>A friend of mine bought a 1965 Austin-Healey 3000. Suddenly I began to think that here was a fellow I always appreciated, but perhaps not as much as I should have. When I commented that the after-market steering wheel did not match the figured walnut dash, he handed me the original wheel covered in cracked Bakelite. He knows I do not take commissions, but that I sometimes do favors. The challenge was too much to resist. Besides, I'd get to test drive the result.
I had a piece of crotch walnut I bought years ago from a toothless guy. This was the project it was waiting for. I roughed out some segments and removed the Bakelite from the original.
I glued the segments to the laminated walnut shown above and routed the approximate shape using a plywood template. I made the template using a trim router with a custom bottom and a nail for the pivot point.
I routed the groove for the wire on the router table.
I then carved out the bits for where the spokes enter the rim and tested the fit.
Hey, this might turn out. Too big though, so I rounded it over and ended up removing considerable thickness from the inside, primarily by rasp.
I cut the finger grips with a half round file and put a coat of walnut dye (made from walnut husks, see toolsforworkingwood.com).
Some work painting the hub and a few coats of a UV varnish and it was ready to install.
BEFORE:
AFTER, including new shift knob:
Oh, you'll want to see the exterior too. This is actually a different car, but his looks just like it. Yes, it is fun to drive!
Re: I made a steering wheel
help me Mr. Wizard!
>Oh great and wonderful Moderator Guy, please make my pictures show! THANKS!
No problem ;-))
Dan Donaldson
Steering wheel
Philip Duffy
>Tom, Fantastic! Now, go buy a "woodie" and put one of those wheels on it and watch the heads turn in all corners of the globe! Phil
Scott in Douglassville, PA
>That is just too cool...
Awesome craftsmanship! Wow!!!
David G. Sparks
What do you charge for a gear shift knob?
Lee Schierer - McKean, PA
>Nice work. I'm sure it will be the envy of the other owners, assuming he can keep it on the road. Austin Healeys are notorious for breaking down.
I could use a shift knob like that for my Miata....:)
Lee
GalenV in Iowa
>What a favor for a friend.
He owes you big time for the fantastic job.
Matching gear shift knob.
Now is he saying how shabby the window crank knobs are and how nice some of the dash knobs would look if they match?
You'll probalby get a lot of request if he goes to auto club or shows, so each one could be another challenge.
By the way I have a Nissan with a cracked leather wheel myself and no talent to make myself! Hint, hint.
Galen
question
Bill Tindall, E.TN
>Would you please provide details on the gluing procedure- what used, how held while curing, etc?
Just awesome!
You are a BAD man ! WOW !
steve mackay
Really cool!
Stephen Kirk in Quakertown PA
>Nice job indeed. The new wheel matches up perfectly.
Wowsa! That's cool!
>Oh man....that is way cool! Your friend is lucky. I am impressed with how you crafted it too!
Thanks for posting.
Tom
Alan Young
Wheely wonderful work.
Alan Young
Best be careful, here, Tom
>If the British car folks in your area get wind that you're doing such beautiful work, you'll get besieged with requests - could become a second career.
OT: my two favorite British car jokes...
Q: "Why did it take the British so long to get going with computers?"
A: "It took forever for the engineers to figure out how to make them leak oil all over the floor."
Q: "Why do the British drink warm beer?"
A: "Lucas makes their refrigerators."
honestly
>If I had it to do again, and I may, I would use more thinner laminated layers to glue the segments to, because the figured segments themselves offer little strength. They are effectively just rubbed together, so the clamping of the laminated layers and the segments TO the layers are the only strong joints.
And I would stagger the seam on the segments (front layer versus back layer) which I did not do. Titebond 2 or 3 would be fine for the walnut glue-ups and I would again use epoxy for the final glue-up of the front ring to the back ring around the original wire.
Re: honestly
Fred Davis
>Beautiful work Tom, and your thoughts on doing a different approach echoed a thought that flitted though my head , just wondering here if your friend while really getting on it , in a tight curve and busy down shifting had a glue failure , just a thought ;-))
FredD
My all-time dream car!!
Bob Slocum
Re: My Dad had a '66
Brian in Brighton
>I remember the wheel as your original. Where did you get the wire version of it? I like it a lot more.
Dad's was a rusting bucket from Chicago when he moved to DC and had someone working on it. He gave it to the guy before my Dad died in 1986 in exchange for having worked on it. It was white with a red interior and black top.
I wanted to smack him when he told me it was gone. It would have been the coolest car in high school for me. :-(
Brian in Brighton
