Best glue for difficult glue up?
B.K. Moring in Jacksonville
>I have a 19" wide dovetailed case for a chest of drawers that I need to glue up. A couple of the pieces(DT pins)have slight warpage and I have to use my panel clamps to squeeze them flat when I dry fit them into the tails. It could take as long as 20 min to get case together along with adjusting the clamps, squaring up, etc.
What is the best glue for this? I normally use gorilla or titebond II but I'm concerned about the time. Any other suggestions would be appreciated. Thanks.
Re: Best glue for difficult glue up?
Dan Donaldson
>I would use liquid hide glue and keep the temperature toward the low end of the scale. Should give good open time.
Another vote for hide glue
David Yoho
>I'll second what Dan said. I've used it on blanket chests where all four outside corners were dovetailed. One nice thing about the liquid hide glue is it will make your joints go together like you greased them. Snug fitting dovetails slide together easier than when dry fitted. This may help your alignment issue at glue-up.
David
suggestions some different than you asked
Bill Tindall, E.TN
>1. 20 min to glue up a case of any sort is about 4 times more time than it needs to take. You should be asking how to shorten your time. What part(s) of assembly is taking all this time?
2. Gorilla glue and Titebond II have no useful place in interior furniture construction.
3. I once used yellow or white glue for everything, but I have come to appreciate the slow tack properties of liquid hide for case assembly.
Bob Boswood
>I am by no means an expert. I am finishing up 3 dovetailed blanket chests. I experienced some warpage as well after gluing up the panels. I screwed some temporary cleats to the inside of the 2 panels that warped to flatten them out for assembly and glue up. I too decided I needed more open time glue and decide to go with epoxy. You have to be careful with the amount you use so as to not have a lot of squeeze out. I used masking tape to keep most of the epoxy of places it shouldn't be. After the epoxy set I simply removed the cleats and continued with the project. I may pay for it later but I think its going to wrok just fine.
Bob in AK.
Bill Spievak
>A friend of mine had similar issues with the glue up of a chest. He dry fitted the case together, squared all corners and clamped all sides to bring the joints together. Then, without taking any clamps off, he used the thin cyanoacralate glue to wick into the joints. I had my doubts, but he had read about this technique in one of the woodworking magazines and was confident. I have to say it worked well in this situation. His joints were close fitting and yet the glue went into the joints and didn't leave a lot to clean up.
