Hazard Data for common solvents
>Compound Name, Boiling point (oC), Flash point (oF), LEL, UEL, Vapor pressure (mm Hg)
Acetone, 56.5, 0, 2.6%, 12.8%, 400 @ 40 C
Ethanol,78.3, 55.6, 3.3%, 19.0%, 40 @19 C
Ethyl Acetate, 77.2, 24, 2.2%, 11.0%, 100 @ 28 C
Isopropyl Alcohol, 82.6, 53, 2.5%, 12.0%,
Gasoline, 39, ~-40, 1.3%, 7.6%, varies
Kerosene, 175-325, 50-220, 0.7%, 6.0%,
Mineral Spirits (light), 149-213, 100, 0.7%, 7.0%,
Mineral Spirits (heavy), 177-211, 140, 0.7%, 6.0%,
VM&P Naphtha, 116-144, 45, 1.3%, 10.2%, 18 @ 25 C
Paint Thinner, 161-197, 105-114, 1.0%, 6.0%, varies
Toluene, 110.4, 40, 1.3%, 7.0%, 36.7 @ 30
Data for this table comes from Hazardous Chemicals Desk Reference and the Merck Index, 11th edition and other sources such as MSDS. If anyone has any other solvents that they want added, I'll do so. If ya'll want densities and miscible data I can add that too.
As an explanation. LEL is the lower explosive limit. It is the minimum concentration in air for a vapor to sustain an explosion. UEL is the highest concentration in air for a vapor to sustain an explosion. Below the LEL it is too lean. Above the UEL, it is too rich. I've put the data for Flash point in Fahrenheit as most readers are more comfortable with that. Flash Point is the lowest temperature at which a compound can flash or catch fire. Vapor pressure gives you a feel for how easily a compound will transition to a vapor. 760 mm Hg is "standard" atmospheric pressure.
Gasoline, Kerosene, Mineral Spirits, Naphtha and Paint Thinner are mixtures. They contain a variety of compounds. As such they can be different from different manufacturers.
