Dispoz- a-blade
David in Indy
>I recently replaced the knives in my Delta 15" planer with the "self set" dispoz-a-blade system from ESTA-USA. Shortly after the change, one of the knives moved up out of position during operation, causing, as you might expect, what looked like the largest snipe ever. I reinstalled the blades, making sure to tighten all of the screws that hold the blades in position. It worked fine for a couple of weeks until the same problem occurred yesterday, completely destroying a panel I had worked some time on.
Before I call the manufacturer or dig out the jack screws I removed and go back to the old blade system, I wanted to see if anyone else had encountered a similar problem or had any more specific suggestions to address the problem. Thanks.
