Rotating table saw blade by hand
Mitch from Canada
>Hi everyone,
I have a Unisaw I bought a few months ago. I noticed that when I rotate the blade by hand..say to check alignment..there is a section/area in the rotation where the blade wants to rotate on it's own. If I want to check blade alignment, I have to place a piece of wood under the blade teeth, or it won't stay where I need it. Is this normal? Everything else seems good with the saw.
Thanks in advance.
Mitch
Re: Rotating table saw blade by hand
Sounds Like
>A slight bit of "memory" in your belts. Had the same thing on my JET cabinet saw until I switched to a link-belt set up. No more memory.
Re: Sounds Like
>I think Mark is probably right and replacing the belts with link belts might be the answer. But Doesn't a Unisaw have two or three short close belts? Might be a PITA to get link belts to work cprrectly after they are installed.
Does it always do this? I suspect the belts acquired a set or memory after the machine was assembled, as it sat, waiting for you to take it home. Or perhaps they have a memory built in from when they were made. Have you tried warming them up by running the saw for a minute or two and then trying your set up?
Another thought is to try loosening the belts and slipping them to new positions that would offset their current memory.
Links
>were easy to put on the 3 sheave arbor on my saw. Fit one to the proper length. Count the links. Make 2 more. Thing is, since the drive and arbor sheave-sets are opposite (inboard-to-outboard), you have to set all three belts at the same time.
2 hints:
a. You do want to make sure that all three are running in the same (proper) direction [DAMHIKT]; look for the little arrows near the edges for the direction of rotation.
b. Use the red "Fenner" drives. My experience is that they run smoother and quieter than others.
I use Fenners on every belt drive in my shop except for the Stubby which takes a poly-V.
mm
Fred Davis
>Mitch,
If the belts appear to be in good condition , don't worry about the movement , it'snot unusual.
If you opt to replace the belts , you need to buy a matched set of belts, which means the belts were cut consectutively from the same belt sleeve.
This a design requirement of the Unisaw and promotes the least amount of vibration caused by belts and gives each belt the same amount of drive force.
FredD
normal?....same here
Bill Tindall, E.TN
>I have had my saw 30+ years and it has done what you describe for as long as I remember. I never had this feature affect anything I ever wanted to do.
Thanks. all.
Mitch from Canada
>Thnaks everyone.
The saw is 10 years old. The belt thing makes sense..and I'm not going to touch them. I just wanted to be sure it wasn't anything I should worry about.
Have a great day!
Mitch
Nick Tuzzolino
>As Barry mentioned, I run the saw a moment or so to warm the belts and eliminate the flat/memory spots.
Pass....Out of curiosity?????
>I agree with all of the above and believe there is no reason to change the belts unless you just want to. I am curious about the "memory" in the belts. I think it is harmless or perhaps slightly annoying at worst, but I was wondering if it is the same memory every time. That is, is it permanently established in the belts or does it reestablish itself each time you turn the saw off and allow the belts to cool down? You could put a (Sharpie) mark on a tooth and watch to see if that tooth always returns to the same position when the saw stops.
I should worry about something else. I don't even own a cabinet saw.
Ralph Turney in Huntington Beach, CA
>I always thought it was a trait of the magnets in the motor.
