Powermatic 54A Jointer Door
Ken Bellock (Houston, TX)
>I just purchased a used Powermatic 54A jointer. Beautiful machine. I'm trying to get the door open on the back of the base. I feel like the kid who keeps pushing away on the door with the big "pull" sign, but figured I would ask you guys for the quick answer. I got the manual with it, but it doesn't show how to operate the door. The diagram shows a "door lock" on the inside, which I figure is stuck engaged. I tried turning the knob counter clockwise, but it turned all the way out... and then I heard a plop on the inside. GRRRR Any advice would be appreciated before I remove the top or try to flip it over. The diagram in the manual makes it look like it slides up and out, but it will not budge.
Thanks for any help,
Ken
Re: Powermatic 54A Jointer Door
Fred Davis
>Ke,
like you say "it's a beautiful machine" don't risk damage by turning it over, call PM in McMinnville Tennesee.
FredD
>Yup, would have called them before posting, but they are closed on the weekends, and I was hoping to get her open this weekend.
I figured someone here had the same jointer, and knew how to pop that door off.
Thanks,
Ken
Got It!
>The handle to the door was just poorly designed. The trick was turning clockwise to loosen the locking mechanism, if you turn it counter clockwise as I did the first time, you turn the bolt off the inside and the handle pops off. The whole thing was very tight, so it ended up taking a towel and pipe wrench to ease it off. Once it was off I dowsed the mechanism in Boeshield. Everything works perfectly now, and no damage done.
Ken
Re: Got It!
Fred Davis
>Ken ,
I haven't seen the handle on the jointer you describe, but the one on the access door of my PM 66 is the poorest excuse for a locking handle I ever saw.
FredD
