Jointer Adjustment
Jointer Adjustment
Jointer Adjustment
Bob Rueter
>I need some help. I have a Delta DJ-30 12" jointer, bought used several years ago. I changed the blades just after I got it & it ran fine for 2+ years of occasional use.
I recently swapped out the blades & was getting snipe at the tail end of every piece. I checked my install, and found that the blade was above the outfeed table.
I swapped knives again the other day, this time with a narrower - ie bevel tip to base, not width - Amana set. These are about 1.5" deep instead of 2" deep, and do not sit as proud of the outfeed table on top of the springs when not pressed down. Thus, it is easier to press them in & adjust to the instructions. The DJ-30 instructions say to have a .015" gap between the high-spot of the blade and the outfeed table. I did this with a feeler gauge.
Now I am getting what I would call dive on every board. The board pushes into the tips of the outfeed table, no matter what setting height I have the infeed table on - level, 1mm, 2mm, etc.
Any suggestions would be appreciated.
Bob
Re: Jointer Adjustment
DouginDenver
>0.015" below the outfeed table? Rule of thumb is to have the knives at their highest point just above the outfeed table. As little as possible basically - but just above. Below is not right for sure. I made a jig with wood, rare earth magnets and a cheap dial gauge so it's pretty easy to set mine at a consistent 1/1,000th above.
Bill Tindall, E.TN
>A more complete understanding of how the jointer works would help in your quest for proper adjustment. Perhaps if you made a drawing- a horizontal line for the outfeed and infeed table and a circle in between for the arc of the cutter head. Now imagine a board being pushed across the infeed table (line you drew) and the cutter head removing everything from that board tat is between the infeed table and the top of the cutter head. If the outfeed table (the line you drew) is above the circle of the cutter head the end of the board is going to ram into it. And if it is below, the board will drop down upon exiting the infeed table and cause a snipe.
The outfeed table must be at the same height as the top of the cutter head for all to work alright.
I am not familiar with this jointer but surely it must have an adjustable out feed table. One sets the knives all at the same height and then raises or lowers the outfeed table to get rid of snipe......or at least that is how I do it.
Lee Schierer - McKean, PA
>I agree, the knives hould be at or slightly above the height of the outfeed table. Ideally the top of the arc of the blades should be tangent to the surface of the out feed table, no higher no lower.
Lee
Fred Davis
>If your DJ 30 is anything like my DJ 20 , I bet the tables are out of plane, they use a eccentric cam setup , that is a giant pain to adjust.
I had to get mine adjusted by a millwright that does it all day for Lenexa tools and it is starting to exhibit the same problem again.
The locking stud on the cam apparently gets loose and then the cam lets one corner of the infeed table drop slightly
Really a aggravation.
FredD
FredD
Tony - Memphis
>The reference I use is an old "rule"of thumb. I set the knives to where they will move a ruler that is resting on the outfeed table about 1/8". That seems to work fine for me. I can't tell you what the height is relative to the outfeed, but it is barely above the outfeed table. The engineer in me used a dial indicator to get them "perfectly" aligned with the outfeed the first time I did this many years ago...but that didn't work. Someone mentioned table droop - I've had that happen before too. I just had to tighten up a gib screw. These things can be extremely frustrating, so be patient. Let us know what the solution is so we can learn from it. Thanks and good luck with it. I've considered an insert hear (the new helix kind or an Esta), but those cost as much as my whole jointer (its a 6" Griz). Maybe someday. Actually, when I get the 8", I'll get one then.
Tony
PS The first advice I got for my "first time" was to set aside most of a saturday and pull up a nice comfy stool!
engineering approach
Bill Tindall, E.TN
>I admire the engineering approach to these things but I came to rely on the empirical approach. I spend the effort to get the knives all the same height ( I wish I was more proficient at this task) and then I adjust the out feed table height to where there aren't problems- snipe or board end crashing. I like to start with snipe and raise table till it goes away.
Empirical Engineering
David Yoho
>I suppose not having any engineering background to draw from, the way I go about it is a combination of Tony's and Bill's methods. Last year when I replaced the original Delta 3-knife cutterhead in my 8-inch jointer with a Byrd head, I found the following to work very well and the easiest for me.
I lay a flat piece of scrap wood (a ruler works well too) on the outfeed table so that enough protrudes over the cutterhead as to make contact. Unlike the original cutterhead, the Byrd has no height adjustment. Before the Byrd, I always made my initial height adjustment to the outfeed table by adjusting the knives to the point where they would just catch the end of the piece of wood and move it about 1/8-inch. However, with the Byrd head I set the outfeed table height to the point where the stick moved the same as before at both ends of the cutterhead. Then I adjusted the infeed table for my normal cutting depth, and ran a piece of stock through to check my setup. I adjusted the outfeed table until the surface of the test piece was flat end to end and locked it down.
I've got a dial indicator and magnetic holder I could use for this operation but it doesn't work any better than the simple approach I use!
David
Re: Empirical Engineering
Bob Rueter
>Wow! Thank you all...I'll try some of these things & keep you posted. I'll also check the Delta instructions again. I'm pretty sure they do say .015" below the outfeed table.
Bob
Re: engineering approach *LINK*
Phil Smith
>I use engineering approach to get knives the same height then adjust as Bill suggest if I have any snipe or feed issues.
Here is link to good video by Bob Vaughan on setting jointer knives.
Here is link to Finewoodworking article that goes with the video.
http://www.owwm.com/files/PDF/FAQ/JointerKnives.pdf
Jointer Knife setting with Bob Vaughan
Fred Davis
>Davis,
I had a 8 inch Boice-Crane jointer for years and my master machinist brother made me a knife setting tool that reflected the jointers user manual advice on knife height.
This handy little jig is a block of one inch thick aluminum eight inches long and three inches wide with two rare earth magnets set in one half of the surface and the other half is relieved .003 of a inch which corresponds to the recommended height for that jointers knives.
I still use it over the high dollar jig I bought with the Delta D J-20 jointer. You can run the knives right up to the block surface without worrying about dulling a knife.
FredD
