OT Need some 3 way switch Electrical magic
>I have been remodeling a house for my cousin. We completely rewired it. Beside the kitchen door we have a 3 way for the kitchen lights and a switch for the outside light at the door. The other 3 way switch is at the entrance to the all. The power to the kitchen lights is fed to the 3 way at the hall. I failed to provide a HOT feed to the box at the kitchen door for the outside light (MY BAD).
What I have is a two wire for the outside light from the box at the door and a two wire that feeds the kitchen lights. And a three wire between the switches across the kitchen and a two wire feed to the 3way at the hall. (Ignoring the grounds for simplicity, but they are there) I have the blacks and reds connected to the switches and they work. In this scenario, the white wire in the three conductor between the switches carried the neutral across the room and feeds it to the kitchen lights.
The insulation and sheet rock are now in place and fishing new wires will be difficult. There is a very low crawl space and a beam under the wall and the roof comes down low over the door, making access tough. AS nearly as I can tell, none of the black or red wires stays hot all the time, depending on the position of the switches. The question is, can anyone think of a way to rearrange the wires and provide power for the light a the kitchen door?
