"Stapling" a rope rug together *LINK*
Tom Dunlap
>My work as an arborist leaves me [ooo, I just saw the bad pun...groannn :)] with lots of rope that can't be used for climbing or rigging. One use that I've thought about is to make rope rugs. There are plenty of patterns for woven rugs but I want to make flat coiled rugs first.
Painting on an adhesive to the back is one way to hold the rug together I know. But that leaves only a one faced rug.
I'm trying to find some sort of staple type fastener that could be stuck through the ropes to hold the coils together but not be on the surface. One idea was to use a tagging gun. When I looked at them I found that the nylon 'strings' didn't pull tight. Having a tool that injects the fastener and then snugs it up like with the nylon wire bundlers is what I'm looking for.
If I can find the tool I do have some ideas for rugs that would incorporate wood pieces into the rug.
Another thought was to use hog-ring staples to pinch the ropes together. Again, a one sided rug with metal staples to scratch floors.
Using a heavy soldering iron to melt or tack adjoining wraps may work but I don't like the idea of all that melted rope smoke even with good ventilation.
Stitching with heavy thread does work but is time consuming. I've done plenty of whipping and siezing on these ropes using a sailor's palm...not a lot of fun.
Does anyone know of a stapler or binder that might work?
Thanks!
tag gun
