Dishwasher problem (OT)
John E in SC
>I have a whirlpool dishwasher, about 6 years old, that recently started not cleaning very well. Tends to leave a white film on the dishes, particularly plastics, and just not cleaning as well as before. No change in water or detergent. I've checked to make sure the filter and spray arms are clean. I think the problem may be the heating element. When I open the dishwasher mid-cycle, even on the "hi-temp scour" cycle, the water in the bottom is only luke warm, and the heating element does not seem warm at all. Does anyone know if the heating element should be warm to the touch during the wash like I assume it would? There is enough warmth to generate a little puff of steam when you open the door mid-cycle, but I would think the water inside should be pretty hot, which it isn't. I think I can figure out how to check the heating element, but I thought I'd ask some opinions before I spend half a day tearing it out!
Thanks,
John
Re: Dishwasher problem (OT)
Bill Howatt
>I think the water in a dishwasher should be around 140F for the hot wash portion of the cycle. However, I don't know if that is the temperature it gets heated to at the start of the cycle and then it gradually cools during the cycle until the water is changed.
If I were to trouble shoot it I would put a clamp-on ammeter on the wire feeding the heater. Another useful piece of information would be the chart, often stuck on a panel or maybe in the manual, showing the state of the timer contacts as it goes through the entire cleaning cycle.
Bill
Fred Davis
>Check the heat setting on your water heater John, there may be the problem , if your DW does not have a sheath heater that kicks in when the WH water is below about 140 degrees.
FredD
John McGaw
>The same heating element is used to super-heat the wash water (at least in DWs made in the past 20 years) and to heat-dry the dishes. If the dry cycle gets hot then the heater itself is good. There is always the possibility that the control circuitry might be at fault if one cycle heats and the other doesn't.
But to belabor the obvious, is the control that tells the DW to heat too-cold water engaged? My Jenn-Air has an LED indicator which makes it obvious but there may be some that don't.
Final fallback, the heater can be tested for continuity (POWER DISCONNECTED!)
GolfSteve in Calgary
>Check that the water level is adequate during a wash cycle. My washer had a problem with the water supply solenoid, so the washer was not filling enough (and not rinsing enough), which caused similar symptoms as yours.
John E in SC
>The DW has an LED light that lights up and says something to the effect of "heating water", but even when the LED is on, the element still feels cool to the touch. Should have mentioned that before. Guess I know what the weekend will be spent doing!
John
GalenV in Iowa
>I had a similar problem but I found it was the float that controls the water level. Not enough water to wash or get the dishes rinsed off. I could hear the pump running and water splashing but if I opened quickly during cycle I found the water was pulled up till bottom pan was near dry. It could be the heater is not heating the water cause it is not up to that level. Not sure if the heater is also controlled by float at some point in cycle since it is used to heat dry too.
Anyway could be level and the element burned for being hot during longer period with low water?
Galen
