CA chair repair
jim short
>Anybody have an oppinion on tightening loose chair joints with thin and then medium CA glue rather than tying to get the whole chair apart to reglue?
CA chair repair
jim short
Re: CA chair repair, NOT!
Dave Anderson (PacNW)
>Don't, waste your time with CA. CA has great tinsle strength but has very low shear strength. It just fail again. Your best bet is to disassemble the joint, clean and reglue. I use 30 minute epoxy because epoxy is the only glue with sructral(sp), gap filling strength. Chair joints take more abuse than nearly any other application.
Just 2 cents worth,
David Haywood, Mechanicsville, VA
>You might also think about using a product called Chair Doctor. It is a glue substance that soaks into the cells of the wood and causes them to swell thus tightening the joint. You will need to get to clean wood for this to work. This may necessitate drilling a hole through the leg into the tenon and then injecting the glue with the included syringe.
Lee Valley Stocks Chair Doctor
Gerry Wittenberg in North Surrey
david schaefer fairbanks ak
>new Rockler Cat has a gizzmochiee that is an "unbreakqble joint for chairs. new to Rockler called Tenon-Lok System. might give a look first time on line in over a year so dont have e mail take care all
>Chair Doctor works but I don't know for how long. I fixed my mothers chairs this summer. They were just slightly loose not sloppy lose. At Christmas they still looked good.
I prefer to pull the joints apart and reglue but sometimes this is very time consuming and not cost affective so I play it by ear.
Spindle Chair repair
Lee Schierer - McKean, PA
>Adding more glue to a spinlde joint in a wooden chair is almost a complete waste of time. The best way to repair a loose spindle is to take the joint apart, clean out the old glue and reasemble the joint. The problem is that cleaning out the old glue generally opens up the gap between the spindle and the hole it fits in. Ordinary glues don't have good gap filling strength. Epoxies do, but they can be messy and a problem to clean up when they do fail.
One solution for filling the gap that has worked well for me in chair repair is to clean out the hole and the tenon on the spindle, getting rid of all traces of glue and getting both as round as possible. Then take a piece of maple that has one side the same width as the length of the spindle tenon. Using a hand plane, shave off a continuous shaving that is .003-.005" thick. Then coat the spindle with glue and begin wrapping the shaving around the spindle tenon. Once a full wrap is on, apply glue to the outside of that wrap. Continue this process until the spidle tenon is the same diameter as the hole it fits into. Use multiple shavings if needed. Don't worry if you get it a bit too large. Wrap the shaving with a rubber band several times to apply "clamping pressure" while the glue dries. Once the glue is dry, remove the rubber band and check the fit in the hole. Sand or file the tenon to get a snug fit in the hole. Then apply glue to the outside of the tenon and inside the hole, assemble the tenon and clamp it in place. Strap clamps are wonderful for this. Let the glue dry and your chair will be as sturdy as new. This repair method lasts for a long time and can be repeated when necessary with the same result.
Lee
Good tip, Lee. Thanks.
Ellis Walentine, Host
