Can epi be glued
Can epi be glued
Can epi be glued
Frederick harvie
>Has anyone had success gluing kiln dried epi. If so what glue is recomended, The wood has such a high oil content it seems that glue will not stick to it.
Re: Can epi be glued
Re: Can Ipe be glued
Frederick harvie
>sorry for the miss spelling in the original post
Ray Binnicker
>I glued some 2x6's together to make the top for my sharpening bench using regular ole titebond I. It has held together for 10 years now.
Ray Binnicker
>Try wiping it down with mineral spirits and then acetone. That usually gets rid of most of the oils.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Fredrick, As others will tell you, the solvent wash is a good idea on very dense oily woods. But also, if you use a water base glue which requires that the water absorb into the wood to dry, it will take a lot longer for the water to be taken up in woods of this type, since the solvent wash is only effective to a depth about as thin as paper.
I would recommend that you leave it in clamps a lot longer than you normally would, and bringing it in to a really warm place is even better after cleaning of the squeeze out.
I had some cold dense wood fall apart from still wet glue after being clamped over night once.
JoeW in Detroit, MI
>I've used Gorila Glue on a prch swing about 1 year ago. It is still holding. As mentioned above, I wiped the pieces with a solvent (I think I used lacquer thinner) before glueing. Spritzed one piece with water and applied the glue to the other piece.
data
Bill Tindall, E.TN
>We built some planes from it and tested several adhesives. The only one that showed acceptable wood failure is the Epoxy from Lee Valley for oily woods. It works but it stinks something awful.
NO solvent wash!
Michael Dresdner
>Stop and think about this. If you happen to hit the right solvent, one that actually dissolves the resin in the wood (it is resin, by the way, and not oil) all you will be doing will be dissolving said resin and smearing it around on the surface. That is counterproductive and can leave you with even more resin evenly spread on the surface.
The one method that works consistently also has the advantage of being supported by the science behind it. Sand the surface immediately before gluing. Here's why this works:
The problem with very resinous woods is that the resin tends to exude from the wood and collect on the surface. This takes a bit of time, meaning hours or more, but once enough gets onto the surface, it can form a barrier to waterbased glue, which adheres to the hydroxl groups on the surface of the wood. As long as there are bonding sites on the surface, what is happening below, deeper into the wood, is irrelevant. Cutting or sanding the wood leaves it a clean, cellulose heavy surface -- something glue can grab on to. There may be lots of resin down below, but it does not matter, because once that glue cures, the resin can not exude through it nor dissolve it to weaken its bond.
Thus, if you sand the wood, even lightly, just before glue up, that is all you need do and you will get a very good bond.
By the way, we luthiers (former luthier, in my case) have known this for generations because we've long worked with very resinous woods.
suggestion
Bill Tindall, E.TN
>You have received a number of suggestions some of which we tried and they failed. In the end test what ever you decide to use to see for yourself what kind of bond it makes. Glue overlapping test pieces together and after curing bash them apart (I put one leg in a vice and hit the other). If you don't get wood failure then the adhesive wasn't very effective.
I recommend epoxy, too
Ellis Walentine, Host
>I just glued up some ipe panels recently using epoxy and they're holding together very nicely. I haven't failure tested them, though, and I imagine that for interior use, regular yellow glue or even hide glue would work.
Agreed!
Paul Woolson
>As another luthier and user of lots of resinous woods, this it true. If you wipe it down you do two things: 1) smear an even coating of resin over the entire surface (as stated before) and 2) the drying action of the acetone (or whatever solvent is used) will actually draw the resins out of the inner parts of the wood and literally push the drying glue from the surface.
A fresh joint is really all you need. I use Cocobolo all the time which is one of the most resinous woods I've ever seen and have never had a bonding problem.
If you are still paranoid, try using some Poly glue (Gorilla or the like) which sticks to anything.
Re: NO solvent wash!
Fred Davis
>I agree with Mike on this issue , it has been known for a long time that washing or wiping exotic woods with solvent actually made the bleeding worse, not better.
How the myth of wiping with solvent got started is probably the same way they all did.
When I edge glue Teak , I hit the edges with a card scraper before glueing and have not had a failure yet.
FredD
