REAL MILK PAINT
Piano Makers- What wood do they use?
Alan Young
Alan Young
>I'd like to know what woods piano makers use for basic production. Steinway, Yamaha, Baldwin-what ever shows up in the "Black Piano Show Room." I believe the finish is usually a polished lacquer with numerous steps. Is there a particular wood chosen for pianos that will provide the best base for the ending black finish. For example-Is walnut chosen because it's already dark? Or is the choice of wood a non factor?
Alan
Re: Piano Makers- What wood do they use?
R. Gryder
>Alan,
Long time ago I worked for Kohler and Campbell piano Co. The veneer they used for the black (they called it ebony) pianos was whatever was available. If it would a sand out smooth enough the black lacquer took care of the rest. K & C went out of business some years ago. R.
Dick Coers
>From what I've seen on TV, Steinway uses hard maple. Fairly easy to get the long pieces of veneer, something over 20' long for a grand piano, and very dense with small pores. They stopped using lacquer a long time ago, they use a polyester base finish now. More solids, faster build, less coats.
Gleamed this off a post on woodweb;
Baldwin Pianos use ILVA brand finishes. I believe they use the polyester over a black basecoat, then sand level, then ILVA's 2-part acrylic urethane clear topcoat. ILVA products are available from their US distributor, IC&S in Lancaster, PA.
Alan Young
This is helpful information
Alan Young
>I finished this little cabinet a month or so ago and will be making another one.
This was Walnut and Mahogany for the framing and Baltic Birch for the top. I guess I was pleased enough with the results but I'd like to pursue an even smoother gloss finish if possible. The legs and especially the side frames have edges and curves that pose challenges. A closed pore wood like maple is now on the list for consideration.
Alan
chuckbeck in cent il
>What wood? All woods! I am guessing you are just referring to case veneer. Some like Boston pianos ebonize oak on their uprights and use maple or poplar on grands. I have worked on a few old uprights from the late 19th early 20th that have a top veneer of figured walnut or a Dalbergia and a perpendicular veneer or mahogany underneath to keep the top veneer from moving. Rims and cases are made from beech, poplar, and these days lots of mdf and some particle board. Keys are bass wood, white pine, poplar, sometimes maple. Wippens, backchecks, damper heads, balanciers all tend to be maple. Ok, I'll quit.
chuckbeck
Bill Tindall, E.TN
>I don't know anything about pianos but the old lumber grading books had grading standards especially for maple to be used in pianos.
wilbur
>Fazioli pianos use beech and mahogany -- beech on the inner layers, and mahogany on the outside. Steinway, as has been mentioned, uses hard maple.
These choices have to be at least in part due to the sound of the piano that the manufacturer is going for. Although there is a lot going on in a piano that contributes to the sound, the sides of the piano is a factor, much like the wood choice for the backs and sides of a guitar. My bet is that the finishability of the wood is probably the least important factor for the serious piano manufacturers.
Robert Lemon - Sacramento CA
>Alan, Here are a couple of pictures of an old coin operated piano. We rebuilt the case with various new parts and cross banded white oak veneer.
The case structure was originally chestnut lumber core, complete with worm holes! It is veneered with poplar cross banding and quarter sawn white oak. The original veneer had been cut with a very large circular saw. Since we had to make up the original dimensions, we had to apply the cross banding and sand it down on a drum sander so the peeled top veneer would bring the case back to original dimensions. All veneering and most moldings, except the veneer on the top panel with glass, are new. The lower portion of the piano was all rotten and had to be replaced or rebuilt. The insides of the case were all reveneered with beautiful birdseye maple.
Bob
>Another pic...
The finish consists of Golden Oak stain, seal coat of Dewaxed shellac, filled with a mixture of dark English Oak oil stain and fine silica epoxy filler. (This was troweled on with a Handyman card) After it set, the excess was wiped off with a course rag. It was then overcoated with another coat of shellac, then a couple of coats of waterbased finish was applied. That was all fine sanded and rubbed out with 4-0 steel wool. The final sanding and rub out is what gives the fine closed grain finish.
Bob
Re: Piano Makers- What wood do they use? *LINK*
>I checked this book out of the library a couple of years ago. It was a fascinating read.
Piano
Bill White
>Case materials are not relevant to the finish (black). Stain grades are obviously specie required. Important wood is in the sound board.
My first job in the '50s was in a piano shop cleaning up old players for rebuilding into studio uprights. Some of the old growth sitka spruce was unbelieveable. Even found some solid wood cases from time to time.
There was a lot of poplar used under veneer.
Bill
Bill,
Did you ever rebuild a player? I had one that hemorrhaged vacuum making it unplayable. I spent a very enjoyable month in the early '80s rebuilding the works - all new bellow's cloth, hoses, tubes, hammers, dampers, and bass strings. Nothing but hide glue.
