Veritas - Innovation in Tools
O.T. - still insulating our new house
Terry Alexander
>Still building our house in West Texas and you guys and gals have been invaluable in your suggestions and advise.
Framing complete.
Roof installed (metal).
Brick installed.
Wiring complete.
Almost ready for drywall.
Before the drywall, we are doing our own insulation.
I have some Tyvek left over from the exterior.
Q: Would it do any good (or harm) to put Tyvek over in interior insulation?
Seems like a good idea to me...but then again...that's why I always defer to the experts.
As always....TIA for your valued input.
Terry Alexander in West Texas (north of Abilene).
Re: O.T. - still insulating our new house
Fred Davis
>Terry,
you run the risk of trapping moisture in the wall , this occurs when cold air from the outside hits the warm side of the Tyvek your thinking of putting on the inside wall.
The insulation batt paper cover is all of the vapor barrier you'll need on the inside.
Glad to hear your progressing right alone .
FredD
Nat Robison
>I've heard the same thing......you never want to have 2 vapor barriers on the same surface. Condensation can get trapped between the 2 barriers. I suppose you could insulate with unfaced batts and put up the Tyvek over them if you really wanted to use it up.
Steve Schoene
>Vapor barriers are a very complex topic and whether or not to have them and where to put them depends on the climate and other aspects of the house's construction. See:
http://beta.buildingscience.com/documents/reports/rr-0410-vapor-barriers-and-wall-design/view?topic=/resources/vapor_barrier_code_changes
Also, be aware that tyvek is not a vapor barrier. It is designed specifically to let vapor pass, while blocking liquid water.
GalenV in Iowa
>Hope that plumbing is done too before that drywall!
Just kidding about your list :>)
I'm too old to go through that again.
Hope you are finding building materials and hopefully some labor cheaper now.
Depending on how much work you are doing, that labor rate is always cheap right?
Won't make any difference
>There's no vapor in West Tejas, anyway.
Clint
