Band Saw
Band Saw
Band Saw
Jack Putnam
>I have a 14inch Band Saw made in Taiwan. The problem I'm having is when I try to cut a piece of wood on the narrow side and holding the wood against the fence so it won't move out, it won't cut straight down the center the blade want's to wander. The cut is wavey. What am I doing wrong?
Appreciate any help you can give. Thank You.
Re: Band Saw
Re: Band Saw
chuckbeck in cent il
>Probably one of two things. First get rid of the fence for minute and mark a line on that board you just wasted parallel to the edge. Now free hand a cut down that line about 6 inches long and stop. Grab a bevel gauge or mark a line on the table along the edge of the board. You'll see the line probably isn't going to be parallel to the fence's line. All bandsaw blades have their own line they like to cut to, its called drift. If you change blades, the drift angle will change and you have to find it again.
..Or your blade is really dull, and you can learn to sharpen it, or buy a new one.
Re: Band Saw
Re: Band Saw
Jim Dillon
>Jack,
Or your tension spring is weaker than it should be. Might be worthwhile to invest in a quality tension spring. The Carter brand comes to mind and is available from different vendors IIRC, or the tension spring sold by Iturra Designs. There may be other brands as well. Good luck.
Jim
Re: Band Saw
Re: Band Saw
Jim Dillon
>Jack,
One more thing. If you are still using the stock 1/4 inch blade that likely came with the saw, you might consider investing in a blade designed for resawing and 1/2 inch wide. There was a thread on this topic recently and different favorite brands were mentioned such as the Woodslicer from Highland Hardware, Suffolk Mfg Timberwolf, Olsen, Lenox and probably others that I can't remember right now. If you do decide to get a wider blade, having a good tension spring becomes even more important.
Jim
Re: Band Saw
Re: Band Saw
>Jack I had one of those and all I can say is good luck. Seriously though, buy a good blade, the woodslicer from Highland hardware worked for me. Crank the tension up beyond what the guides say. Slow down your cutting rate, and follow what the others have said. With that saw I pretty much had to assume I would only get 1/4" pieces from a 3/4" board, and that was on a good day.
I bought a Delta which looked like they could have come from the same factory. Virtually all the problems I had went away. I still get a little wander but it's usually because I'm using an inexpensive blade that is probably a little dull. I do crank the tension up. Fine Woodworking had an article about making a tension gauge by clamping 2 pieces of wood on the blade and measuring the gap with a feeler gauge. Then tension until you expanded that gap by X amount. I tested several blades and made marks on the tension guide. That worked OK.
I now have a riser block on my bandsaw and you can see the blade on the left side running through the channel. I adjust the tension until this long section doesn't vibrate. That has been working very well.
Re: Band Saw
Re: Band Saw
William H. Falberg
>Jack, it sounds like you're kinda new to band saws and pretty much clueless. I'd do a little Google searching for band saw "how to" s. Like how to re-saw; how to tension a band saw blade, band saw fencing, band saw blade selection, band saw blade drift, etc. Watch the year the article was written; currenter is betterer. There's a ton of free info on the web and if I was you I'd spend some time researching woodworking web forums like this before I spent a dime in money. You probably just need a better, sharper blade - but there's a lot more to it and you can't go from 0-60 on a band saw. It's a complex machine with lots of dynamics you need to understand. Enjoy the journey!
Re: Band Saw
Re: Band Saw
Alan S
>Have you carefully set guide blocks and thrust bearing close to the blade AFTER making sure the blade tracks well and runs smoothly? If the thrust bearing is pushing the blade forward, you will never get it to cut straight. Then check drift angle and cut rate. If you cut too fast for the tooth size, the gullets fill with dust and the blade must twist to be able to cut.
That said, the blade is usually the culprit.
