Sliding dovetails in plywood?
lee beeden
>I have some very nice vertical grain fir plywood and i am going to build a entertainment centre.
I will use traditional face frame construction with mortise and tenons and then biscuits to attach to the plywood.
What about keeping the case together at the back or bowing on the sides?
There will be no drawers, just shelves.
Are dadoes for the shelves stronger enough to keep the case from coming apart at the back?
I was thinking about some kind of web frame using sliding dovetails, the shelves could rest on this web frame, how does this joint work in plywood?
Any comments appreciated
Lee
Re: Sliding dovetails in plywood?
David Yoho
>Lee, in all the cabinets I've built from plywood, I've always attached the shelves to the case sides with a dado and the cabinet never pulled apart. After a back is installed, it will certainly lock the rear of the case together. Today's glues create very strong bonds, making these simple joints work well.
However, if you had some concern that the plywood you have wasn't flat to start with or might not remain flat once assembled for some reason, there's no reason you couldn't use sliding dovetails to connect the shelves to the case and keep things from pulling outward.
Your call,
David
Agreed
Nat Robison
>I've only built one entertainment center and it was one of my first big projects. Anyway, I built it with dadoes and glue and there's never been an issue. I also agree with David that once the back is attached, the whole box is "locked in". As long as it's square before the back goes on, you should be fine with dadoes and glue.
Dick Coers
>With the poor quality of plywood these days, I would think that you will have a lot of chip out and a devil of a time fitting a sliding dovetail. The glue seems to just barely hold the veneers together, and I never use imported plywood. I would think it would be very hard to hold a sharp corner on the male dovetail. I strongly suggest doing a trial cut or two.
