We value your privacy.
>Over the past 28 years my cabinets have not only darkened, they have "aged." The finish has dulled (actual comparison with interior side of doors) to the point they look lifeless, and, because at least one member of my family uses the sides, bottoms and/or tops of doors as a handle instead of the handle they SHOULD BE USING! (rant off now), the finish, including stain, has been worn away in many places.
I am sure that part of this was my fault beginning many years ago when I didn't know any better. Because all the ads insisted that the wood in my cabinets needed to be 'fed' regularly, we used Scott's Liquid Gold or similar products on a regular basis. We stopped using the Liquid Gold a few years ago, but the damage was done...the surfaces that were regularly treated just look dull...about 50% of the sheen still present on the inside of the door.
As for the wearing away of the finish, it literally is that...the finish is totally gone in areas where fingernails have gradually worn it away. There are no gouges, nor can I feel any ridges where the surface has been chipped away; everything feels smooth.
The original finish was a sprayed on oil base stain (stupid me followed the cabinet guy's suggestion back when I didn't know better...NO stain on cherry, EVER!), followed by sanding sealer, followed by laquer (don't know how many coats...2, I believe). I have tried to color the bare areas by applying a bit of stain, but the areas that appear bare will accept little or no stain. It is as if the wood has a protective coat on it.
I'm not a refinisher by any means. I don't know where to go from here. Any ideas, either for the dull finish or for the bare areas?
>Joe, it sounds like there's still topcoat in the wood if you can't get it to take stain. However, a dye might work at penetrating and providing some color. Otherwise, if the color doesn't come back after applying only a coat of topcoat, you might have to strip the wood and start fresh.
As to your dull finish dilemma, I think you could solve that by first making sure the surfaces are clean and grease-free, then a light scuff sanding to smooth things a bit, followed by spraying on more coats of lacquer.
