We value your privacy.
>All of our kitchen, bath and utility room cabinets are cherry. Two things have happened over the past 28 years, both of which lead to problems. #1 - the cherry has darkened considerably. #2 - the cabinet hardware has worn and corroded to the point that my sweetheart says it has to go; she is tired of looking at brown-green where antique brass used to be.
The kitchen hardware (Amerock) was not terribly expensive when we bought it in 1981, but it was somewhat unique...a 'pitcher' type cabinet door handle and coordinating drawer pull with integral backplate, both of which had a somewhat unique shape. Add that mounting surfice shape to the off center construction of the door handle to the darkening of the cherry surrounding the pulls and handles and you now have an idea of my problem...cherry doors and drawers with light spots that I can't cover up.
I have spent a minimum of 10 hours on-line and in cabinet shops trying to find pulls and handles to cover these spots entirely. I have also looked at backplates to cover them, using handles or knobs on the backplates. The problem is that the backplates are either so large that they are almost obscene or are too short on one end (the pitcher pull was not centered on the 3" screw centers as the backing plates are.
One option I have been made aware of us having the existing hardware refinished. My problem is that my past 2 hours searching the web has produced only industrial replating companies, none of which look like they would do my little (60+pulls, plus, maybe, 90+ hinges).
I am looking for sources that might refinish my original hardware. Or, I am looking for reasonable, good-chance-of-success methods of doing something similar myself. Any suggestions? (I am in northern Ohio, but will do business anywhere I have to.).
Picture a metal plate 3" in diameter laying on a piece of cherry for 28 years. Now remove the plate. You have a much lighter circle 3" round on a darkened piece of cherry. Now superimpose a 2" metal square on the light circle. The square covers only part of the 3" circle. The part of the circle not covered stands out like a gravy spot on a white shirt.
Not meant to be a rant, just an explanation and request for help from friends who might be have information I'm not experienced enough to have. Sorry.
I'm lost as you say in first memo the backing plate had screws 3" on center but then say later the backing left a 3" circle on the wood?
Was the backing plate just under one screw and the tail end of the handle off the backing onto the other hole.
Agree picture needed.
Would think old hinges would be worn out and not reuse even if you got recoated.
Can the old backing plates be refinish plated or painted and work with another style handle?
Not knowing look that you are trying to maintain then not sure how you may adapt new handles. Black cut plexiglass backing cut to shape needed with commercial handle?
Just a guess without pic. Is this what you call a pitcher pull?
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
Guest
Re: No pics; better analogy.
>Joe, Sorry for calling your request a rant.
Now I think I understand what you are dealing with. There are some chemicals which darken the cherry by oxidation. I believe caustic soda is one, which is in oven cleaner. You might try masking the area around the circle, then placing a screw through one of those disk, while you scribe around it with a sharp knife. When you remove the disk, you can peal the mask out from under where the disk has been.
This stuff is also a pretty good finish stripper, so it might help in removing the finish which was probably in good shape under there, as compared to the exposed area around it. This may be worth a try, but I would not expect perfection. You might just get better control by just staining the area.
"you can send a sample to Amerock's Customer Service department: Amerock Corporation Attn: Customer Service/Consumer Specialist 29 E.Stephenson Street Freeport, IL 61032 Please include your name, shipping address, telephone number and a note stating what you need and when you purchased them."
or simply call them: 1-800-435-6959
They should be able to give you the model # so you can buy replacements. If the model is no longer manufactured they should be able to provide a list of exact size replacements.
Sorry, my explanation and analogy were written late at night, so they seem to run together...poor concentration after a long day. The circle analogy was to illustrate that not all of the undarkened wood would be covered by any new pull I have been able to find. The original pull actually has a fleur-de-lies (sp?) design at the top, a design larger than any replacement I have been able to find.
Yes, this is a pitcher pull design. Mine is similar, but elongated, which causes the problem. The holes are 3" between centers, but the actual holes are NOT centered on the length of the pull. The pull is 5.5" long. The first hole is 1" from the bottom, the second is 4" from the bottom. That leaves 1.5" of the pull above the top hole...and 1.5" of undarkened cherry where the top of the pull would be. Of the dozens and dozens of pulls I have looked at, the longest length above the top hole is only 1", which would leave .5" of undarkened cherry exposed.
>Thanks Curly! I was so tied up in scanning their catalog that I missed this possibility. I will call them Monday. With my luck, though, they will have sold the last one last Friday.
>Have you looked at woodworkershardware.com for hardware? The have a HUGE catalog full of hardware, and just about all the mfgs knobs/pulls/backs listed. I had similar issue and found pieces to work for me there: http://www.woodworkershardware.com
I agree with the notion of replacing your hinges. If your hinges were anything like mine, they weren't even worth cleaning them up myself, let alone sending them out to be done. If they had the plastic self closing pieces in the hinge, most are probably broken. I refurbished my 25 year old solid oak kitchen cabinets last year, and replaced all the hinges with Blum Euro hinges. Got them at the site above for less then $2 each (Blum Compact #38N 105 degree).
But the handles... even if you have 100+, if you like them, it shouldn't take much to clean them up. Do them a few at a time while you watch TV! If they are solid brass, buy BRASSO or NEVER DULL (I think GLITZ is another, but I've never used it). I've used the Brasso with an old electric toothbrush on knobs before, and they cleaned up in a snap.
