Wood welder?
Wood welder?
Wood welder?
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Do any of you have experience using wood welders? Are they safe?
I have wondered if they would work with a vacuum bag for veneering? I was wondering if it would be risky for getting even coverage. Would too much heat be problematic, since the boiling point is cooler in a vacuum. Would it hurt the glue to over-cook etc.?
Re: Wood welder?
Sorry about double post.... But sometime
>I hit the post message button, and later find that it didn't ever show up. I went back and found my email address was missing, and hit Post again.
Re: Wood welder?
Re: Wood welder?
John Luke
Used one for years, safe as long as you don't put the hand unit to your forehead and pull the trigger.
I wouldn't reccomend it for curing glue in a vacuum bag.
The Wood Welder is for curing glue joints such as in gluing up edge glued panels, stick and cope doors. etc.
Not for a large surface like veneering a panel, you would get uneven coverage and if you were to draw an arc you could burn a hole in vacuum bag.
Re: Wood welder?
Thanks John,
>I don't think I would be trying the forehead thing, but I am not sure about why or how to strike an arc. Is it like welding, where you drag it across,,,,,,,,,,,, uh wood, while pulling the trigger?
Does it just have a small range of coverage?
Re: Wood welder?
Re: Thanks John,
John Luke
>Sometimes it will make an arc to for some reason I don't know to the wood, sometimes to one of the pencil lines for lining up panels.
The range is the area between the electrodes which are placed across the glue line.
For panels I "tack weld" the ends and every several inches to hold the panel together, take panel out of clamps and set aside for rest of glue line to cure, and lay up the next panel.
Try Googling workright wood welder to find their site for more info.
Re: Wood welder?
Interesting site. Never heard of such a thing...
John E in SC
>Just out of curiosity, how much does such a critter cost? I imagine it would be much too much for a home shop, but looks pretty neat. Maybe Norm needs one of those so he can stop using brads to "hold it together until the glue sets."
John
Re: Wood welder?
Re: Wood welder? *LINK*
Tom Dunlap
>A link...
Work Rite
