Router Wrench - used to raise bits in router table
JEB
>Hello all,
After making an extension table to my table saw to use as router table a few years ago, I'd been searching for a way to make changing bits easier. I have a FREUD router that uses a threaded rod and knob to raise/lower the bit. It's easy to adjust, but because of the length of the rod, it takes forever. So I wanted an easier/quicker way to do it - such as the top of the table setups, but didn't want to pay the heavy price of the systems on the market.
To solve part of the puzzle, I purchased a 'Collet Extension' from MLCS Woodworking, that now allows me to change the bits above the table. Now I just needed to solve the raising and lowering issue.
After seeing all the various contraptions other guys were making, I was certain that I could come up with something simpler - more low-tech, instead of the other complicated hi-tech methods. Especially since mine couldn't stay setup. What I ended up with was a simple portable drill driven 'Wrench' that I use in my cordless drill that allows me to easily and quickly raise and lower bits.
This Wrench idea was so simple and easy, I don't know why it took me so long to think of it! I thought I'd pass along the idea, in case others may be interested. As long as your router has the adjusting style like I have on my FREUD (FT2000E) router (that I know some other brand routers do have), and an open table you can use my Router Wrench.
If I did it correctly, you can see a pic of my Router 'Wrench' below:
I hope you find this tip helpful...JEB
Re: Router Wrench - used to raise bits in router table
>Neat solution, but to do it right, you should have a Freud drill too.
Very clever.
Neat Idea JEB, For What Its Worth.......
>Good evening JEB,
I bought a JessEm Mast-R-Lift to raise my PC 7518 in the table. It comes supplied with a hex wrench which operated from the table insert top. Your solution is a good one, so I thought it curious that JessEm has stated that employing a drill to drive the hex bar voids their warranty. Certainly this has no direct application to your set up. I just wanted acquaint others of a possible potential problem. I am satisfied with the JessEm(although I have issues with the counter clockwise, counter intuitive, tightening direction of the insert plate), but would like to use a hex bar attached to a little drill driver to position my router setting more quickly. I like your idea and application.
George
George
Re: Neat Idea JEB, For What Its Worth.......
JEB
>Hi George, thanks for your comments.
I didn't elaborate on my post, (as I did on my official 'Tool Tip' on my website that's under construction) for anyone that may want to make my Router Wrench to make sure to set the drill or driver at the low speed, and turn the torque dial way down to avoid over tightening and/or stripping out the threads on the router. As well as not to use it with a standard corded drill without the speed or torque adjustment options.
From what I could see on the JessEm Rout-R-Lift, the adjustment is basically the same type (threaded rod) as I have on my Freud router - and it didn't have any type of anti-torque device. So that may be the reason for the disclamer. (Not that I'm recommending) but I would think as along as you used a drill/driver as I noted with my Wrench with the low speed and torque, there'd be no danger of over torquing any of the parts and messing it up.
In my case, with my Freud router, I don't think it will hurt the router if I'd forget to turn down the speed or torque as it has a long rod and with the added Collet Extension, I never run it to either end of the stops anyway. But if it did happen, I think I'd do more harm to myself when it hits the stop and the drill twists out of my hand!
Thanks again...JEB
