THE WOODRAT IS BACK!
dust collection
dust collection
dust collection
Ed Quintrell
>Could anyone advise me if there would be a disadvantage in running dust collection pipe in a crawl space under the shop ( cold space ) verse's inside on ceiling. Would cold area be a negative effect on air flow? I would appreciate any advice .
Regards
Ed Quintrell
Re: dust collection
Re: dust collection
>I'm just theorizing here. But I think not. Where are you, how cold is that crawl space?
Assuming the pipe is not insulated, the air passing through it would be cooled slightly depending on what the pipe is made of and how long it is and the air speed, and the temp in the shop and the crawl, probably a little heat loss, but not much.
If the DC is in the shop and the air returns to the shop, the heat loss would be minimal. My DC is out side and I like it. The dust is GONE without regard to the quality of the filter, etc. I have more heat loss, but not as much as you might think. You only lose the heat in the air and the shop recovers quickly. I only run it when the machines are on. Much quieter this way also.
If the ducts leak and are under negative pressure, you might suck air out of the crawl and blow it out into the shop. This could be a source for mold and radon. Pretty unlikely and not at all if the ducts are sealed and they should be.
Might be tough to clean out a clog, depending on the crawl space and the duct lay out. Its a good thing to leave access to the ducts. I have had one or two "incidents". Couple of long thin slivers plunged into the system beside the TS blade and those long curls off the lather are not a good thing in the impeller.
Re: dust collection
PS.......
>Running the pipes down and back up is not a good idea. If you do, use careful design or you may get clogs. You need excellent air speed to keep the particles flying all the way to the bag.
Re: dust collection
Re: dust collection
GalenV in Iowa
>Would think condensation plus dust equal a cake and not the tasty kind? Unless you are in a warm dry climate.
But then that is not based on experience as today was shopping day for my own DC.
Re: dust collection
Re: dust collection
>Should work nicely. As Barry said, there may be some marginal heat loss. If it is too much, that's why they make insulation :).
Design is the biggest problem. Incorporate clean outs just in case. You'll probably want to have hatches in the floor rather than stubs coming out of the floor. If your hatches are close fitting, they can act as blast gates.
Re: dust collection
Re: dust collection
Chuck in ND
>Galen has a good point, if the inside of the pipes under the floor sweat, you may create a heck of a mess inside the pipe in short time.
Re: dust collection
Re: dust collection *LINK*
Alan in Little Washington (NC)
>I have had not any problems with my second story shop DC piping which runs along the ceiling of the unheated garage below. Check out the pics and description in the shop contest.
Shop Contest
Re: dust collection
Re: dust collection
Ed Quintrell
>thanks for the info on dust collection
best regards Ed Quintrell
