REAL MILK PAINT
Ramset tool
Ramset tool
Ramset tool
Mike Baker
>Hi all!
I need some help, I purchased a simple single shot Ramset triggered power hammer. I'm trying to fasten 2x4 to concrete. I cannot get the tool to set the drive pin (nail) to full depth.(1/2 inch shy)
I first tried a 3" long pin, then tried a 2 1/2 pin, and using the strongest power level load available (Yellow)
Any Ideas??
Thanks in advance
Mike
Re: Ramset tool
Re: Ramset tool
Fred Davis
>Yellow won't make it , look for some Purple loads.
FredD
Re: Ramset tool
Re: Ramset tool
>Hopefully you are pressing the Ramset to the 2 x 4 with a lot of pressure. I usually use the #4 load for long nails into concrete. I've also used two of the #3 loads.
Re: Ramset tool
Re: Ramset tool
Mike Baker
>I am pressing the tool tightly to the 2x4, alot of pressure.
Ramset says that only a Yellow #$ is available for the tool. Strongest load.
JL how do yo shoot 2 #3 loads in a single shot tool??
Mike
Re: Ramset tool
Re: Ramset tool
>THIS IS NOT A RECOMMENDED PROCEDURE - DO THIS AT YOUR OWN RISK.
What I have done (wearing safety glasses, ear protectors and a safety shield) - is slip the barrel over the exposed nail and fire the Ramset with another cartridge. I've done it with two #3s and a #3 and a #2. If you do it with too great a charge, the nail will be embedded in the board.
If you choose to do it this way, be very careful - it can break a nail and send it flying.
Re: Ramset tool
Re: Ramset tool
Fred Davis
>Omark , Remington, and Ramset had Remingtons full line of loads for power actuated devices , the Yellow load is intended for use on green concrete, Purple and silver colored loads were for seasoned concrete and metal up to 3/8ths inch.
It has been a while since I used my Omark , which has gone out of business, but I still have the loads.
Maybe you were talking to a person unaware of the full range of capabilities of a Powder actuated device ( love that term, only a California civil servant could think that up ).
FredD
Re: Ramset tool
Re: Ramset tool
Mike Baker
>I called Ramset Technical advice!
They told me that the yellow charge is the most powerful load available for the gun I bought, and that if the concrete is old and seasoned, I will have to step up and buy a BIG BOY gun that shoots .27 calber loads instead!!
I have decided to use Tapcon screws now! They are working well,, just more work, and not near the fun!!
Thank you all for the help!!
Mike
Re: Ramset tool
Re: Ramset tool *LINK*
John McGaw
>Seems possible that Ramset might have stopped making purple .22 loads. Or so their website suggests. I used to use them a lot myself, fastening through light steel into concrete.
http://www.ramset.com/loads_chart.asp
Re: Ramset tool
Drill a hole first...
Jim Rahbe
>Mike,
I ran into the same problem. I simply predrilled a small hole in the 2x 4 first. About half the size of the nail. I adjusted the size of the hole slightly until I found one that would allow the nail head to be set just below the surface of the 2 X 4.. There are also two manufactures of the nails.. RAMSet and someone else, Remington maybe.. One of them is fatter than the other and I could never get that brand to work right. The thinner ones worked much better. If you wish, I can tell you which nail worked for me, but not until tomorrow, as they are at my daughter�s house..
Jim R.
Re: Ramset tool
Re: Ramset tool
Fred Davis
>Mike , you are probably right , but Ramset must have changed over the years , a step up caliber was .25 and if that didn't get it done , you could get a gun designed for .38 caliber.
In California they require a license to operate a powder actuated device, don't know where you live but they must have told you that , huh ?
FredD
